Automate Plug In Preset Changes
I've tried to search for a definitive answer on this but haven't found it so I apologize if this question has been answered before...
I've created my own user plug in presets for Amp Farm and other Plug in's. What I'm trying to do is automate the selection of the presents so the presets change at different points of the song.... That way I can simply change presets instead of going through all the tweaking for every change... It would seem that changing the preset is not one of the selected parameters for the plug in so I'm stuck.... (It is interesting that in the Venue D-Show software there is a simple way to do this....) Cheers |
Re: Automate Plug In Preset Changes
You should be able to do this with snap shot automation. Select the plugin and enable all the parameters to be automatable. Go into Automation Off mode on the selected track. Select the area on the track that you want the preset to be on, select the preset in the amp farm plugin, then hit option command / this will write automation to all enabled parameters. (be aware that this will overwrite any other automation in the track unless you disable those parameters in the master automation enable window). Select the next area for the different preset, then pull up the preset in Amp Farm, option command / and it will snap shot those values to the selected area.
Thanks Bobby - hecka simple once it's explained!
NI Guitar Rig 4 Automate preset change | abt | Pro Tools 9 | 1 | 07-30-2011 05:08 AM |
How to Automate a Plugin's PRESET?? | teacherman | Pro Tools TDM Systems (Mac) | 13 | 02-03-2008 05:42 AM |
Can't Automate plug-ins | MTX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-15-2006 11:25 AM |
How to automate plug-ins | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-23-2005 02:07 AM |
Anyone know how to automate EQ preset changes? | ncaoili | Pro Tools TDM Systems (Mac) | 11 | 04-11-2002 07:21 PM |
