2018.7 hanging on 'Waves shield 9.92 at start up
At start up, PT's hangs at Waves plug,,,I've been using a different daw for quite a while now, but still check in on PT's updates. This one looks interesting in some ways so thought I'd give a go. Although I've pointed PT's to the waves plug folder, (which is where it's always been!!) It keeps going back to asking where the file is. Have to restart to close PT's, task manager won't do it?? Any ideas,,,, Thanks, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Re: 2018.7 hanging on 'Waves shield 9.92 at start up
IIRC, Waves is at V10. Maybe you need to update? I have no issues with Waves and PT 2018.7.
Hey thanks,,,, I hadn't realized that. Always try to avoid the good ole WUP as long as possible, but might not be a bad time to check it out!?? Might also try a reinstall, see what happens. Time permitting...… Appreciate the idea. I'm quite sure this is one of those one off situations,,,, if there is a problem to have, I'll have it! Story of my life!
I'm on version 10 and Waves would hang at start up than crash. After a reinstall of Waves everything has worked fine for the past several days with no problems.
Sent from my SM-N950U using Tapatalk
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
I had Waves 9.92 running fine with 2018.7 before I updated v10. Maybe the re-installing all Waves stuff would help (like abc1mce2 did).
Thanks guys, seems to make more sense than reinstalling PT's,,, we'll see what happens.
Well I thought I had Waves 9.9.2 because PT's asked for it, but I only have 9.2.0and 9.2.6!! SOooo,,,, looks like WUP time. Its been a while anyway. Might go ahead and get the SSL plugs. Or might just change it up and go with UAD??
Man,,,,,thats not right either! I checked some of the Waves while in Studio One,,, they're all showing the 9.9.2 vers…? Even though my Waves acc. shows only 9.2. Confused as usual, I need to try to reinstall Waves.
If you have Waves 9.anything, your license should be good for Waves 9.anythingelse. Try reinstalling Waves Central (gulp), but whatever you do, DON'T check the "update my plugins" tick box. It will update them to v10 which you don't have a license for, and that's a whole world of pain to unpick.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
Reinstall all waves plugins usually fixes this for me.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
hanging PT app start/looking for control surfaces | adam_w1 | Pro Tools 2018 | 2 | 07-31-2018 11:30 AM |
Pro Tools 10 HD hanging on start up | lBeaman | macOS | 2 | 02-21-2015 09:26 AM |
Pro Tools LE Hanging on Start Up with installation of secondary internal HDD | plangentmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-10-2010 10:51 AM |
structure hanging up start of pt8 | agill711 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-28-2009 12:24 AM |
B&W G3 hanging on Digi init on start up | joepopp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-11-2001 12:25 AM |
