#21
Re: Pro Tools and 9093 Errors
Another thing I’ve noticed is sometimes the session will run fine for a while and then the errors start happening. A Pro Tools restart buys some time but it happens again.
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
#22
I can say it's a given that any project I open, when I first hit play I get an error. Same will happen if I come to a part where a new instrument plug comes in.
It's extremely disappointing that you are having problems with a powerful computer. My plan was to do the same in terms of upgrading and I had the same expectations as you. Now not so sure. C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#23
Sorry just saw this reply, yeah I think its pretty relevant to the source of the errors, but as this is a 'Hackintosh' system, I'm not sure that AVID would be interested.
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
#24
In this case it's been using the Abbey Roads consoles from Waves. Specifically the TG12345. 15-20 tracks each with an instance of the TG12345. Hit play, goes for maybe 5 seconds before the cpu meter goes solid red and I get noises (not music) and 9173 error. If I remove all instances of said plugin the session plays fine. Can't just bypass it and things are okay - deletion is the only thing that works. If I use Waves NLS and use Mike's console which is a TG12345 on every track - no problem. This is on the system in my profile where I can run 60+ track sessions no problem. I don't have any Waves V12 but a mix of 9/10/11. |
#25
I have just built a system from scratch. MP 5.1 12 core w/24GB ram, running High Sierra, PT Ult 2020.11 with HDX 2. I had only Avid, McDSP and iZotope RX8. 9093 issues. Installed Waves 9.92 Platinium, same issues.
The errors seem to be random. CPU has plenty of room, pushing both HDX cards. |
#26
Bumping this thread as it seem relevant to me.
Mac Studio running 12.6.1, PT 2022.5 and an Omni via Thunderbolt HD Native. Every few days I get a -9093 on opening PT for the first time and hitting Play. Sometimes a similar error about the video engine or CPU. The only solution seems to be a full restart of the computer and power cycling the Omni. Once it works it will work all day with multiple sessions. It feels like an initial hardware sync issue. I know the Omni is an ageing beast but it should still be reliable. |
#27
#28
I'm on the latest HD Drivers as far as I know, and Omni firmware. The Native card is the Thunderbolt one so is connected via a TB2/TB4 adapter. It may be that the Mac Studio TB4 bus isn't totally happy with the TB2 connection. What's odd is that it does work most of the time! I'm holding off an update to PT until we get a stable native version so I doubt I'll find a solution in the meantime. |
#29
#30
Possibly, although others seem to be using HD Native Thunderbolt with TB4 -
https://duc.avid.com/showthread.php?t=419509 I suspect your article above is talking about cables rather than protocols. However, it may still be a compatibility issue, just not a consistent one! |
- 9093 & -9129 Errors, Pro Tools LE 8.03 | Jabberock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-15-2010 10:22 AM |
Stinkin' DAE errors 9093, 9129 on playback in Pro Tools LE 8 | lmeney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-26-2010 09:10 AM |
overcome pro-tools errors 9092, 9093, 9094 | Deni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2008 11:59 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
-9093 same old errors and I've tried EVERYTHING | unclecolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-19-2006 12:02 AM |
