Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 02-21-2011, 09:22 AM
wirefall wirefall is offline
Default DSP Power for SoundDesigner II
Hi folks,
as I still use SoundDesigner II for some Jurassic Park synthmonsters:
Which is the most powerful hardware regarding DSP power for SDII?
Goal is to run SDII with plugins, but an Audiomedia II or III ( I have both) hasn't got much DSP power, e.g. for chaining Waves plugs.
Best would be Nubus-Hardware, but also hints for PCI are welcome!
Old 02-21-2011, 02:19 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: DSP Power for SoundDesigner II
I think, but don't quote me on this, you could run the last version of SDII with Pro Tools III hardware. Not sure if that included the PCI version of PTIII or not.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 02-21-2011, 07:55 PM
milesofwire milesofwire is offline
PT III PCI was indeed the last TDM hardware to support SD II, however only Nubus hardware would support plugins in SD II, and there was no performance benefit with TDM (PT III), AM III hardware works the same.
Old 02-22-2011, 02:12 AM
Thanks a lot!
So an Audiomedia is already the top regarding DSP power for SDII plugins?
Old 02-24-2011, 11:25 AM
That's the way I remember it, the plugins in SD II work like an AudioSuite one if I remember correctly, so TDM Isn't used or needed, again any PCI hardware will not support the use of plugins in SD II.
Old 02-27-2011, 07:50 AM
Thanks a lot guys!
HTML code is On
Future of SoundDesigner II Matthias Allgayer Digidesign Hardware & Software 109 07-16-2002 03:23 AM
SoundDesigner II files.... Daniel_Isaiah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 06:52 AM
SoundDesigner and G4 AGP cameleon Digidesign Hardware & Software 11 06-15-2000 11:31 AM
SoundDesigner w/001? Fredrics Digidesign Hardware & Software 3 02-06-2000 12:57 AM
Sounddesigner for CD burning? tintom Digidesign Hardware & Software 2 04-13-1998 12:06 AM
