Old 04-25-2019, 12:38 PM
babaorum babaorum is offline
Default Pro Tools 2018.12 won't to close
Every-time when I close : session can be closed but Main Pro Tools refuse to close ... and freeze ...
Pro Tools 2024.3 - Cubase pro 113 64bits- Windows 10 pro 64bits - wavelab 12 pro - core i9 9900K - 32 Go RAM All SSD- interface : ANTELOPE ORION Synergy Core.
Ideal-Sound Not_To_Flow
Old 05-04-2019, 09:02 PM
Jazzbass56 Jazzbass56 is offline
Default Re: Pro Tools 2018.12 won't to close
What OS are you on Windows or Mac?
On my Windows 10 pro PT 2018.12
Freezes almost all the time when I quite, I then “ End Task”
And it closes, I don’t have this problem on Mac OS
Intel Intel Core i7-5930K 3.5 GHz Processor
ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram
Thunderbolt EX 2
Windows 10 Pro
2013 MacBook Pro Retina i7 Quad-core, 16gb ram.
Mac OSX 10.11.6
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
Memory 128 GB 1866 MHZ DDR3
Graphics AMD FirePro D700 6144 MB
PT Ultimate 2022.4.0 on Mac
PT Ultimate 2020.12 on Windows
Logic Pro X 10.6
Nuendo 12.0
1_Antelope Audio_Orion Synergy Core Studio
Old 05-04-2019, 09:05 PM
nige108's Avatar
nige108 nige108 is offline
Yep same here. W10.
Also, when you minimise PT to the task bar it gets stuck there. You have to hover over it then right click and choose restore.
Quite annoying.
Old 05-04-2019, 09:12 PM
As always, start by trashing prefs. If it happens with one session.., it may be corrupt. If it happens with multiple the suspect plugins... check all plugins are up to date and try removing third party .aaxplugin files in batches from the plugin folder and try to identify the culprit plugin(s). The plugin may not necessarily be instantiated In the session to cause problems (just installed in the plugin folder), but is more a suspect if it is. Quick test is obviously to remove all .aaxplugin files from the plugin folder, then trash prefs, restart Pro Tools and see if it happens then. If so it's not a third party plugin--but this exact problem can/has be caused by plugins.
Make sure all session file are stored on NTFS, not exFAT or other, filesystems. Still stuck create a new Admin account and test with a new empty session from that account. Still stuck, uninstall and reinstall Pro Tools.
Start at “help us help you” at the top of each DUC web page. You have lots of troubleshooting to do, if you need more help here describe clearly what troubleshooting you have done, and include a SiSoft Sandra report
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Pro Tools HD 2018.1 - Preferences & I/o VERY slow to close DrFord Pro Tools 2018 4 01-26-2018 04:27 PM
pro tools wont close out` chdrummer Windows 8 05-14-2012 07:34 AM
Cant close or save pro tools le 7.3.1 zcustomman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-27-2007 11:41 AM
Error Trying To Close Pro Tools... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2006 02:56 PM
