Old 02-25-2019, 10:13 PM
musicmixer04 musicmixer04 is offline
Default Dimmed solo button?
I have worked in Pro Tools for a long time but its the first time I noticed this. Solo button on one of the tracks are dimmed. Anyone knows?
Old 02-25-2019, 11:29 PM
kelsey's Avatar
kelsey kelsey is offline
Default Re: Dimmed solo button?
Are you using a Satellite Link? From the PT manual:
Track Solo Indicator Lights yellow when any track in the session is soloed. When no tracks in the session are soloed, the Track Solo indicator ap- pears dim green. For systems using Satellite Link, the Track Solo indicator lights dim yellow when a track is soloed on any satellite system.
https://wanderingear.net
Last edited by kelsey; 02-26-2019 at 05:17 PM. Reason: Looked closer at the picture.
Old 02-26-2019, 10:08 PM
arneal arneal is offline
This is very easy to do accidentally - at least for me it is. Just command-click on the solo button and it should go back to "normal".
Reg
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6
Old 02-26-2019, 10:19 PM
kelsey's Avatar
At first I also thought a track was solo-safed, but looking at the picture the dimmed solo button is yellow, not the dimmed grey that a solo safed track would be.
Old 02-26-2019, 11:07 PM
TrackerLe TrackerLe is offline
you can solo a Track, which is in Solo Safe mode. Then its dimmed and yellow...
Old 02-27-2019, 10:01 AM
kelsey's Avatar
When I solo a solo safed track, the solo button is the same saturation of yellow as a non solo safed track. PT 2018.12
Old 02-27-2019, 02:36 PM
dwaynedelario dwaynedelario is offline
Is the dim solo appearing on a VCA? Your solo mode is probably in latch. If you solo the VCA and then a track which it is controlling, you get the dim yellow solo.
MacOS 12.4 / Pro Tools Ultimate 2022.4
Old 04-15-2019, 02:14 PM
Hi
Thanks for all replies. sry it took a while to respond.
Yes its a dimmed yellow on a VCA so this is spot on:
Thanks for helping, I learned something new:)
Cheers
New dock solo button lower then mute button Sean Bombz Avid S1, S3, Dock and Control App 14 10-12-2017 06:05 AM
Solo button afarid Pro Tools 12 2 04-05-2017 05:01 AM
Is the solo button in PT LE REALLY this retarded? FordVan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-04-2010 12:16 PM
Solo button blackbirdstudio Pro Tools TDM Systems (Mac) 5 01-29-2009 08:11 AM
solo button of pT 4.3.1 mr cawn Pro Tools TDM Systems (Mac) 3 07-10-2000 04:27 PM
