strike mix preset--which one?
This is strange: Yesterday, on Strike, I selected a mix preset. Today, I'm looking at the list of various Mix presets & there's nothing to indicate which Mix I have selected.
So, how do you know which Mix preset that you're currently using? Where in Strike does it say which Mix preset is loaded? I'm am so lost. Thanks for your help! |
Re: strike mix preset--which one?
The preset, style, kit and mix share the same name....so just go to the main window, hover your mouse over one of the play buttons at the bottom and it will say what style it is....and because thay share names, that will also be the name of the mix. If you start changing the mix or kit of a preset...name it to recall it again.
Other than that...good old notepad and pencil
003r/i7-930/LE 8.0.1 cs2 on xp |
Thanks so much for the help! This is what happened to me: I did change the Mix & that's why I don't know what the name of the Mix is now.
The preset that I started with is called 'grunge 115.' However, I changed the 'Mix' to something else. I simply don't remember what 'Mix' that I chose. I really thought that Strike would somehow indicate which Mix I'm currently using, but it sounds to me like it doesn't, from what you're saying. Did I understand you correctly: If I select a Preset Style, then change the Mix--using a different Mix preset--the only way for me to know what Mix I've selected is to write it down on paper or save it to a User Setting? |
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. | We live forever | Virtual Instruments | 55 | 09-17-2012 06:02 PM |
Strike - Songs recorded with Strike - Post Yours | JCWarrior | Virtual Instruments | 12 | 05-16-2011 12:36 PM |
Installed Strike, activated license with iLok> no Strike. | seeeker | Virtual Instruments | 3 | 10-17-2010 04:21 PM |
Upgraded to PTIEP from Strike, do I need to uninstall Strike 1.0.2 first? | cmedina | Virtual Instruments | 0 | 04-20-2010 09:37 AM |
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2008 08:19 PM |
