How to record with Pod farm active
Im using pod farm when i had pt9 le i would arm the track press record and away ya go. But in 9HD when i press record on the track pod farm goes into bypass mode. Is there away to use this on the track with out putting the pod farm on a aux.
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: How to record with Pod farm active
Place a TDM plugin (like the TDM version of the guitar tuner that comes stock with protools) before the Pod Farm.
Thanks anothercolour will this cause latency issues
Raoul Crane
Yes, by a few samples-- it's the only way in HD to make it work. I use a trim plug in, FWIW.
or, you could create an aux channel, set its input to the same audio input that you are recording, put the Pod Farm on that and use it to monitor while recording.
just turn down or mute the recording audio track.
regards, richie. "a paradigm of restraint and good taste at a time of frequent excess" |
Impossible to record audio because Audio Input is not active? | papitopinillo | Windows | 10 | 01-21-2012 10:22 AM |
Aux Sends don't work unless Record Enable is active on track | FrustratedUser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-13-2011 07:26 AM |
8.0.4 allows plugins on active record tracks with LLM? | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-09-2011 10:31 AM |
Track could not be record enabled it does not have an active in/out | crizdee | Pro Tools TDM Systems (Mac) | 1 | 11-22-2010 05:00 PM |
Instrument track in-active, without making it in-active | Ylle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-05-2007 01:18 AM |
