Old 01-17-2014, 09:39 AM
Giftofsound Giftofsound is offline
Default 003 with PT9 CPTK crashes
Hi guys,
I have a crash almost twice a day that forces my to restart the 003 and the pro tools and its becomming a major slowdown with clients.
Is there anyone that can help me identify and learn to avoid this crash?
Here is part of the crash log:
Code:
Process:         Pro Tools [6193]
Path:            /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier:      com.digidesign.ProTools
Version:         9.0.6 (9.0.6f82)
Code Type:       X86 (Native)
Parent Process:  launchd [250]
Date/Time:       2014-01-17 12:37:08.555 -0500
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          59141469 sec
Crashes Since Last Report:           938
Per-App Interval Since Last Report:  48613193 sec
Per-App Crashes Since Last Report:   222
Anonymous UUID:                      291C523C-F3EA-4639-BBB6-73990EB4C03C
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
Matt R. Sherman
Re-Recording Mixer/Sound Editor
http://www.giftofsound.ca
Old 01-17-2014, 10:57 AM
Default Re: 003 with PT9 CPTK crashes
A crash report is of little help with zero details about the system
Help us Help You - READ THIS Before Posting!
Old 01-18-2014, 12:30 PM
Thanks! My bad heres more info about the system!
Mac pro 2x 2.26 quad core intel xeon
8 gigs of ddr 3
Running osx 10.6.8
Has a blackmagic intensity pro for pcie video out
3 x 1TB WD caviar black drives in the system
and 1 WD 4 TB external drive (USB)
Only firewire connected is the 003.
I have an avid mix and avid control hooked up via ethernet as well
Please let me know if there is anything else you need to help solve this! Thanks!
Matt R. Sherman
Old 01-19-2014, 07:29 PM
Trash prefs?
Old 01-20-2014, 07:48 AM
I have already trashed prefs :-(
This issue happens 2-3 times a day. Mainly when closing a session.
The only way to get PT back up and running is a full reboot of the system and the 003.
Thanks please help!
Matt R. Sherman
Old 01-20-2014, 09:39 AM
JoelG's Avatar
JoelG JoelG is offline
Are you using the 11.0 drivers from here:http://avid.force.com/pkb/articles/d...02-003-Drivers
Are you running the latest version of PT 9 available in your Avid account?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 01-22-2014, 10:37 AM
Joel
Yes am completely up to date.
Matt R. Sherman
Old 01-22-2014, 11:48 AM
Can you post a complete crash report, paste across several posts if you need to. A crash report without any stack traces is virtually useless.
Does this only happen with one session? If so, then it's likely corrupted, if so go back to the last workign backup of your session, or create a new session and import the current session content/media into that.
If not, you need to exclude plugins, temporarily move all third party plugins out of their RTAS folder. Trash prefs and databases. Start Pro Tools. Does the problem still happen? If that stopped the problem then put the plugins back in batches to see if you can find the culprit. (you have to do this, just disabling a Plugin within Pro Tools is not sufficient).
If not unisntall everything... Pro Tools (with uninstaller clean option), plugins etc. and reinstall them all again.
Old 01-22-2014, 03:40 PM
Thanks kindly! It does seem to be restricted to one session after further testing! I have imported the session data into a new session and it still seems to happen. Problem is, the crash occurs after heavy mixing and full days, so its hard to reproduce when I am alone! Ill get the full crash report in here as soon as it re-appears! Thanks you so much!
Matt R. Sherman
Old 01-22-2014, 04:11 PM
No problem. And I know what a PITA this can be, even when you think you proved its one things it comes back. And with other crashes recently of Pro Tools 11 folks have had the worst case of things that need some combination of corrupted session and specific plugins. Make sure you are making daily (or more) full backup of your session and saving them elsewhere, and that those backups include all media/content as well.
PT9 + CPTK upgrading to 11 with CPTK functionality but without hardware? Race macOS 1 09-18-2013 08:23 PM
PT10.0.1 and CPTK only there's no CPTK features unlocked Oblivion777 Pro Tools 10 8 02-28-2012 07:55 AM
CPTK 1 + CPTK 2 question boabyd23 macOS 2 10-24-2011 06:13 AM
Why buy CPTK? dccarson Pro Tools 9 4 11-18-2010 03:05 PM
Original CPTK works as CPTK 2 ? JanuS Pro Tools 9 5 11-08-2010 07:40 AM
