Old 02-06-2011, 07:17 AM
muses muses is offline
Default OMF regions don't appear in Edit window
I have imported an OMF file into a PT 9.0.1 session.
The regions appear in the region bin, and the correct number of tracks get created in the Edit window, but no regions appear in the tracks.
I would appreciate any help with this.
As an FYI, I started working on this project in Logic Pro and the OMF imported without any problems. The OMF was created in the latest version of FCP.
Old 02-06-2011, 07:44 AM
suicune suicune is offline
Default Re: OMF regions don't appear in Edit window
In your import session data dialog, do you have under 'main playlist options', 'import - replace existing playlists' selected? Otherwise it will only place the regions in the region list.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 02-06-2011, 11:08 AM
Thank you, suicune ... darndest thing. It's all working fine now.
I did have that checkbox active when doing this earlier, but it simply wasn't working -- and I tried it several times to make sure. I stepped away from the computer for a few hours, and now it's all working correctly.
Sorry for the trouble, but I very much appreciate the quick response. I'm fairly new to PT and I'm happy to know this forum exists.
HTML code is On
Gap between edit window views and regions synth999 Pro Tools TDM Systems (Win) 2 04-26-2011 11:26 PM
Edit window regions not linking with region bin??? dougens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2010 11:31 AM
Parent Regions no longer appear in Edit Window milestone Pro Tools TDM Systems (Mac) 2 03-17-2010 10:29 AM
Quesiton re: Edit Window/Regions on the grid paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-02-2009 06:49 PM
Color coding regions in Edit window? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2001 01:37 PM
