Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-11-2014, 07:40 PM
montelee montelee is offline
Default how to stop pop-up hints?
I just want to know if there is a way to disable those annoying little hints which pop-up in Pro Tools 8 if you hold the mouse over a feature. It especially drives me nuts when using elastic audio- when I hover over a warp marker it insists on telling me what a warp marker is for, making it hard to see details of the track. I have checked preferences and see no mention of it. How do I disable this feature? Thanks.
Gear: 2009 Mac Pro, 8 cores at 2.93GHz, 8GB memory,OS X10.6.8; running Pro Tools 8 M-Powered
Old 02-11-2014, 11:56 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: how to stop pop-up hints?
It is in preferences. Called tool tips. I think it's on the very first page.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-12-2014, 12:27 AM
Hi Chris-
Thanks so much for the helpful reply. Who knew that Pro Tools called those pop-ups "Tool Tips". I found it just like you said on the first page of Preferences. It had two fields under Tool Tips: Function and Details. I don't know what Function refers to but I deselected Details and the pop-ups went away! I am happy again. Thanks.
Monte
Old 11-08-2018, 12:58 PM
Enrico De Paoli's Avatar
Enrico De Paoli Enrico De Paoli is offline
Originally Posted by crizdee View Post
Chris
Worked perfectly. Thank you!
Enrico De Paoli
World Class Music Engineering
Old 11-08-2018, 01:04 PM
BTW tooltip is the proper Windows UI name for these rollover effects. Apple calls them help tags but many developers call them tooltips on Mac as well, to Apple’s apparently frustration.
Euphonix 5-MC Mix Hints dertonmensch System 5 2 01-26-2012 08:31 AM
Any last iLok hints?? kbahjat Pro Tools M-Powered (Mac) 1 03-28-2006 06:47 AM
PT 6.4 (TDM) - Hints at something for us? rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-26-2004 06:34 PM
OMS Names- Hints and Help doc22 MIDI 0 03-08-2001 06:23 AM
hints Yacuza Tips & Tricks 2 02-21-2001 01:46 PM
