Old 01-27-2006, 06:39 PM
soalivetoday soalivetoday is offline
Default Digi001 with XP sound card issues
Hello...I just purchased a used Digi001 unit for use on my XP system. I installed the Digi001 sound card and the software. The software will open and function. However, I am having a big problem getting my CPU to recognize the soundcard properly. When I go to Control Panel> Sounds and Audio Devices, the Volume tab indicates "no audio device" and the drop down box is not functional. However, when I go to the audio tab, the Digi001 card is listed for sound playback and MIDI. I have tried uninstalling XP service pack 2 already as I saw this mentioned in another forum, but have had no luck in getting the sound card to work properly. Any help would be appreciated...thanks!
Old 01-27-2006, 06:54 PM
spkguitar's Avatar
Default Re: Digi001 with XP sound card issues
You need to install the wavedriver. Instructions for it's use should be in the appendix of the Getting started guide that came with the 001.
Old 01-28-2006, 07:10 AM
Thanks, I actually got it working with everything except streaming audio using Digi MME helper. I will install the wave driver as you suggest.
Thanks for the response.
Old 01-28-2006, 07:13 AM
spkguitar's Avatar
If you got everything working, then you already have the wavedriver installed. Keep in mind that the wavedriver is playback only, so you won't be able to select the 001 as a standard windows record device.
Old 01-28-2006, 02:29 PM
I'm starting to see that this is going to be a problem on my XP computer. For instance, I used to run a DAT deck into my Echo Mia MIDI card through s/pdif and record into Wave Lab. When I run the DAT into the s/pdif on the Digi 001, I get nothing.
So basically without a two-way sound driver, I am screwed as far as recording anything other than within Pro Tools?
Getting XP to use Digi001 as sound card, also MIDI SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-23-2007 03:03 PM
PCI sound card & Digi001 Russell Fischer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2005 07:08 PM
Do I need a sound card? I have Digi001? handssum21 MIDI 0 08-19-2003 09:32 PM
How do I use my Digi001 as my main sound card? brentm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-13-2003 11:24 AM
DIGI001 + OTHER PROGRAMS + ANOTHER SOUND CARD??? Elite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-31-2003 11:15 PM
