Old 12-07-2003, 03:33 AM
hotstuff hotstuff is offline
Default Alesis ADAT
I am using an adat as my converter for my 001 setup for more channels (16 in total) but when i arm the channels that i need on the adat the master fader in protools indicates noise (the more channels the more noise) on the idividual channels there is no indication of noise! is this normal? what should i do?
Old 12-07-2003, 03:36 AM
Default Re: Alesis ADAT
I can only hear the noise if i realy turn up the volume!
Old 12-07-2003, 03:54 AM
Kryckmeister Kryckmeister is offline
Seems like your either mik pre's or your ADAT is giving up that noise. My guess is on the pre's. Either have a look at your equipment or consider gating everything (which I think of as the worse alternative).
Anyone using Alesis Adat hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2003 05:19 PM
20 bit Alesis ADAT to 002 BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-05-2003 10:15 PM
Alesis ADAT Edit with LE jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-09-2001 01:52 AM
ALESIS ADAT HD24 surgestrip2001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-19-2001 08:48 PM
Digi001 ADAT, Alesis ADAT Edit and Fostex VM00 phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2001 08:57 AM
