Old 03-03-2003, 04:53 PM
gplus gplus is offline
Default setting up cue
Can anybody help.I have a control24 and an 88824 I have the 888 outputs going back into c24 via 8 male xlr to db25 works fine.I want to use the aux ins and outs to set up a headphone mix using pt 3-4 outputs but my outputs are going into the c24 via this db25 I must really be over looking something here can anybody help.I have many patchbays also if there are some good ways to do this Please let me know.
Old 03-04-2003, 08:23 PM
Nash BBQ Nash BBQ is offline
Default Re: setting up cue
I think there have been posts about this before...
But I use a mackie mixer in the tracking room and send analog outs 3-8 (1&2 go to monitor in on the C24)to the "artist" so they can do their own mix. I do a separate line from the aux outs of the C24 to its own fader for the talkback.
I use aux send 3-8 in PT to send whatever groups I want.
If there are any specific questions, feel free to ask.
BBQ
Old 03-06-2003, 07:56 AM
PDupre PDupre is offline
This is very clearly defined in the manual.
www.peterdupre.com
Old 03-06-2003, 01:01 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
My suggestion would be to run outputs 1-6 from the 888 into the C24 ProTools Sources input using your snake. Then, I would connect ouputs 7-8 from the 888 to the Aux Input on the C24 using XLRF to TRS cables. Run the Aux Output to your talent headphone amp.
In software, setup the 7-8 outputs as the cue output in your I/O Setup. Then, assign a send (I usually use send E for cue) on every track to go out 7-8 and you're all set.
-Eric
setting up brfdrums Getting Started 3 06-13-2013 09:07 AM
I need help with setting up the i/o Mr.johnny5 Getting Started 1 04-19-2013 09:37 PM
Setting up for 5.1 SKYHIENTERTAIN Post - Surround - Video 23 11-03-2007 08:04 AM
Setting Up (HELP) onelly Pro Tools TDM Systems (Mac) 1 11-05-2002 10:28 PM
Setting up for HD--which OS? 9.2.1 or 9.2.2? DaveCarlock Pro Tools TDM Systems (Mac) 2 03-04-2002 11:48 AM
