Synch the three up
How do you synch the three up so that you can record audio. Also how would you connect your midi cables to each piece of equipment. I checked and I have done every thing you mention but I still can't get a midi signal from the mpc into the 001.
Also I only have two outs on my mpc is that going to cause any problems. thank you |
Re: Synch the three up
i don't really know what 3 your referring to...but i sync my mpc by connecting digi001 midi out to mpc midi in...click on midi in pro tools...click on enable beat clock:digi001....then go into your mpc and set it to receieve midi clock...press record in pro tools and it will trigger it
Make sure the frames are the same 30, 25, etc.
THE NUMBER REFERS TO MY TRITON,MPC, AND DIGI 001. ALSO HOW DO YOU PAN LEFT AND RIGHT IF YOU HAVE THE TRITON AND THE MPC RUNING INTO A MIXER(6 CHANNEL MIDIMAN), THEN FROM THE OUTS OF THE MIXER INTO THE DIGI. DO YOU PAN IN THE TRITON AND MPC, OR THE MIXER(6 CHANNEL MIDIMAN), OR PRO TOOLS, OR ALL THREE.
you have alot of options for panning. you can use internal lfos in your triton, record the triton into ptle and use the automation, or send panning data via midi. for the mpc i would record into ptle and automate in the dae enviroment. i hope this helps
cris |
Audio in synch with quicktime, out of synch in FCP | WannabeSQ | Post - Surround - Video | 6 | 09-20-2006 06:47 AM |
Synch issues | The Kooch | Pro Tools TDM Systems (Mac) | 1 | 02-04-2004 02:49 PM |
synch | jimmy? | Digidesign Hardware & Software | 0 | 07-29-2001 12:23 AM |
Do I need a external synch box? | BboY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-20-2001 04:36 PM |
Synch w PT 5LE | Pro Tools TDM Systems (Mac) | 1 | 04-14-2000 09:56 PM |
