Old 07-21-2023, 02:18 PM
Prabha Prabha is offline
Default Dolby Atmos in Pro Tools / Windows is anybody doing it?
Hi guys!
A couple of months ago I decided to implement atmos in my studio, I've been a PC guy since always (30+ years) and so far managed to record and mix quite easily with out even touching a mac with a stick.
But atmos has been quite a different story! there are so many obtacles along the way to do atmos on a PC with Pro Tools, that I'm going mad.
Dolby rederer is a no go if you intend to run it inside the same computer as PT. You can route audio inside PC using ASIO LINK but is a real hassle, has a 64 channel limit, and finally it's impossible
Atmos composer can't do delay compensation when running inside PT. so it's a discarded option
I don't want to run renderer in a second computer.
Is there any other way?
Maybe the industry standard, most expensive daw, should have an embedded renderer...
Thanks!
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Old 07-23-2023, 05:14 PM
Led Led is offline
Default Re: Dolby Atmos in Pro Tools / Windows is anybody doing it?
Only way currently to do it with one system is using Asiolink Pro. It's not really a hassle once you set it up, but as you said limited to 64 channels.
If you don't want to use that, either hold out and hope for a native renderer to be added to Pro Tools, or switch to Mac.
Depends how much call you have for Atmos work I guess..
Old 07-23-2023, 05:46 PM
deanrichard deanrichard is offline
Try the demo for Fiedler Atmos Composer. It's a native solution that (theoretically) will let you render Atmos from within PT itself. I haven't tried it in PT, but it should work. (I'm using Reaper on Windows, and it works there. A few quirks, but it's a viable native solution.)
Originally Posted by Prabha View Post
Hi guys!
Thanks!
Old 07-23-2023, 10:22 PM
Led Led is offline
Not so great in Pro Tools for a couple of reasons..it doesn't do delay comp for plugins, so you have to work it out yourself and offest tracks, and also inserts on audio channels are pre fader, so none of the panning or volume has any effects unless you use an aux for every track.
Old 07-23-2023, 11:23 PM
I have no solution for the delay compensation issues. They don't exist in Reaper, so I can't comment. I don't find the other things very confining because of how I work. One could automate everything through their panner, if desired, but that's not my method. For volume automation of bed tracks I submix to a multi-channel folder track using the Reaper surround panner and use standard DAW volume automation to a 10 channel buss track. I submix the bed tracks using the DAW, then create the Atmos bed from the buss track, with all channels panned to the proper bed location. I like that method as I can do compression, limiting, volume changes, etc. on the entire bed, much like buss FX in a stereo mix. I see it more as a change in workflow than a limitation. I like working that way for bed tracks. I set up a single Atmos panner on the bed track buss.
As for panning of objects, since they need to use their own Atmos panner to send Atmos panning data, I do use their panner. It's not as convenient as the DAW panner, but I see it not so much a limitation as a change in workflow. If desired. one can insert a pre-fader volume plugin and automate it.
Old 07-24-2023, 07:46 AM
Hi Led, are you currently using asio link pro?
What happens with metadata?
Do you enable dolby atmos in the setup>peripherals menu?
If so, what do you do with the network connection?
Do you sync by sending a recorded wave file with SPMTE?
Thanks!
Win 10 64
SSL MX4
Old 07-25-2023, 10:55 PM
Led Led is offline
Thanks!
Hi, yeah enable Dolby Atmos in peripherals with the same local machine you are on as the renderer host instead of over a network. Timecode you generate a mono timecode wav (there are websites you can do it on) and send it tot he renderer on object 64, which you specify in the renderer settings.
Here's a walkthrough vid I did of how I set it up..
https://www.youtube.com/watch?v=eARw4dZ2PxU
Old 07-29-2023, 07:12 PM
Thank you very much Led!
Win 10 64
SSL MX4
What's the deal now with Dolby Atmos on Windows for PT? atticmike Windows 4 12-02-2023 07:45 AM
dolby atmos production suite for windows? zenith_infinitive Pro Tools 0 08-16-2022 06:53 PM
Dolby Atmos for Windows, please! atticmike Windows 6 05-24-2022 01:33 PM
Is there a way to use a 7.2.4 Dolby Atmos home theater as a Pro Tools Dolby Atmos mix Focuret Pro Tools HDX & HD Native Systems (Mac) 19 09-14-2021 08:52 AM
Dolby Atmos on Windows ctv mtl Windows 3 07-31-2020 07:09 AM
