Old 03-17-2023, 07:45 AM
Talisker Talisker is offline
Default PT wouldn't play even one track
I run two versions of pt on a M1 Mac Mini from 2020 on Monterey 12.4. I kept a version of 22.5, but I mostly use the newest one, which is 22.10. The problem applies to both, 'though. It only started recently, that I open a session, not very cpu heavy, especially not for an M1 and the System Usage monitor will show a red line and 100% cpu load and I can't start. Sometimes that even happens with a session that only contains one audio track. And it seems to make a difference, how I load the session. Loading "Recent" sessions seems to be the worst, sometimes I can use "load session from disc" and it works fine, other times I need to close pt and double click the session and start pt from there. Tried to trash prefs. didn't work. I was thinking about a reinstall but then again it appears on both versions of pt. I alway get it to work eventually, but the other day it took me an hour and I'm working for clients. Any thoughts ? thanx
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 03-17-2023, 12:17 PM
nsureit nsureit is offline
Default Re: PT wouldn't play even one track
I’d look at plug-ins. Perhaps a plug-in became unregistered in your iLok account, or a trial period plug-in expired?
Old 03-17-2023, 12:50 PM
I also would start with plugins since you already trashed prefs. Remember that plugins can sometimes screw things up, even if they are not used in a session. I would go to the Plugins folder and move all 3rd party plugins out to a temp folder on the desktop(so its easy to find and delete later on). Next step for me would be to uninstall both PT versions and re-install either for testing. If a single install runs fine, then put the other version back in(no point in having 2 installs if neither is working right)
Old 03-18-2023, 06:52 AM
Thanx. I never know, that a plug in can cause problems, if it is not used in a session. So i will have to sort that.
Old 03-20-2023, 07:39 AM
So I tried both, removed all third party plug ins, malfunction still there. Then I did a clean re-install of only one pro tools version...no change. And it is all a bit randomly, that makes trouble shooting very hard. Maybe it is one session causing the problem, but even that session sometimes loads and works ok. Any more suggestions ?
Old 03-20-2023, 07:54 AM
bradch00 bradch00 is offline
Are the sessions all being read and written to the same drive? Have you tried using an alternate drive as a “session” drive?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 03-21-2023, 02:31 AM
Yes, all the sessions are on the same external hard drive, except the test session with only one audio track. That is on the internal hard drive. So hard drive issues are also out.
Old 03-21-2023, 04:37 AM
its2loud its2loud is offline
What is OSX 10.181.1?
Did you do any OS updates recently or migration assistant restores?
What other software did you recently add to the system?
Remove both versions of Pro Tools. Trash all preferences. Install just one version (2022.12).
Old 03-21-2023, 06:00 AM
Carl Lie Carl Lie is offline
It could be your interface/driver. Not sure where else to look.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 03-21-2023, 07:26 AM
My Mac OS is 12.4, always forget to correct my signature. I did reinstall PT and it still misbehaves.
How can this track play? kywildcat79 Pro Tools 10 1 03-11-2014 07:58 PM
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 09:41 PM
Pro Tools wouldn't play until... mattrussell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-23-2007 09:55 AM
Can you play along with a track without recording? newathis Tips & Tricks 5 01-16-2004 07:56 PM
Mute on audio track switches off when I play the track el biciclista Pro Tools TDM Systems (Mac) 3 07-29-2003 10:54 AM
