Old 11-29-2022, 05:19 AM
Paulienat's Avatar
Paulienat Paulienat is offline
Default Re: AVID S1 (x2) & DOCK + MAC PRO 2019 Setup
Originally Posted by EddieJones View Post
To confirm what others have said:
  • Crossover cables havent been needed for 10+ years
  • You can run the tablets on the Inetrnet routers WiFi (but follow the advice on this page for reliable connections Avid Control KB)
  • The Amazon Fire tablets are very slightly slower than a good/new iPad but it depends on what kind of work you do...
Thanks!
The chance to use an ethernet adapter for hardwired connections is only for Ipad Pro with usb-c? Can I use an ethernet to lightning adapter?
If you connect any tablets with ethernet adapters you lose the option of charging them...is it right?
Mac Pro 2019 - Monterey - Macbook Air M1 - Apollo 8p (x2) - Apollo Twin X - Ferrofish 16Mx - Avid S1 Multi-unit
Old 11-29-2022, 08:32 AM
EddieJones's Avatar
There are lightening adapters too and yes they have charging at the same time. Google is your friend
Old 11-30-2022, 05:53 AM
Paulienat's Avatar
I'm using an iPad Air as master control, wifi-connected to a dedicated TP-Link Router, 1 meter of distance between them and I've noticed that the meters are pretty slow on the screen with some lags. Not the best metering experience.
Connection problems/IP issues? with Avid Control and Avid Dock Voldemort Avid S1, S3, Dock and Control App 6 10-25-2022 02:35 AM
FS: 2 Avid S1 Control Surface and Avid Dock, including 2 Samsung S6 tablets Imagine Buy & Sell 2 10-05-2022 04:03 PM
FS: Avid Dock Jedisteph Buy & Sell 0 08-20-2022 11:36 AM
Avid S1, Dock is not responding. Keisuke Avid S1, S3, Dock and Control App 2 08-29-2021 07:20 AM
(4)S1’s with Dock setup mixboy bob Avid S1, S3, Dock and Control App 19 05-04-2020 01:16 PM
