Old 01-26-2018, 02:46 PM
jre3132 jre3132 is offline
Default 2018.1 and no Automation
I've updated to 2018.1 and have been mixing a song with no issues today (well....one crash). All of the sudden, I noticed some of the panning wasn't working. I started looking into it and all of the pan automation I had written was still there, but it was not reading anything. I thought I had accidentally suspended all automation, but pulled up the window and everything was still active. All the tracks are in read status.
I keep trying different things and have found that the track pan envelope appears to be completely disconnected from the pan control on the track I/O section. It's happening on about 5 tracks out of the 7 or 8 vocal tracks I have running right now. What am I missing???
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 01-26-2018, 03:00 PM
amagras amagras is offline
Default Re: 2018.1 and no Automation
This was officially fixed on 12.8.3, would it be possible that it's broken again or maybe its two different issues that are causing the same behaviour...
I'm going to take a look just in case but I'm on Windows 10.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-26-2018, 03:02 PM
I never had it on 12.8.2 or earlier versions...not that it didn't exist....but it was working on every version until I upgraded to the version that supposedly fixed it. Figures....lol
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 01-26-2018, 03:20 PM
I created a new track and copied the audio (with pan automation) to the new audio track. I bussed the outputs to the same bgv sub where the original track was going and muted the original track. The new track was before the original track.
The result....the original track started working and the new track didn't. Apparently it's a track order or voice order deal? When I switch the order of the tracks and drag the original track before the new track, the new track works but the original track stops working.
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 01-26-2018, 03:41 PM
BScout BScout is offline
Sounds like the "dynamic voicing" system that re-allocates voices. Used to be useful on HD TDM when you were running out of voices. Lower track numbers took priority when there was audio on the track. Not really necessary in HDX world with the increase in voices. What is the "dyn" setting on the bottom of each track as seen in the mixer window? And how many voices are being used (check system usage)?
Old 01-26-2018, 03:52 PM
Yeah, "dyn" in on. I should have mentioned that this particular deal is a guitar vocal. I was mixing a larger file earlier with no issues. This is using 13/256 voices. I was just able to get it to work by duplicating the tracks that weren't working so it either reassigned the voices or re-ordered the tracks. After creating extra tracks, then moving them around, then deleting them, it seems to have reset the pan automation and is reading now. It was a weird combo though where either the original or duplicated track would not work, then switch over to working. Thought I was going crazy watching the lines move, but not the knob...
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
ProTools 2018.1 PTPerson ICON & C|24 4 02-19-2018 01:08 PM
PT 2018.1 and Yosemite ? wwittman Pro Tools 2018 6 02-12-2018 05:38 PM
Pro Tools 2018.1 (12.9) thanos4 Pro Tools 2018 160 02-05-2018 07:41 AM
Pro Tools v2018.1 Now Available DigiTechSupt Technical Alerts 0 01-25-2018 11:06 AM
