cubase vst and 001- separate outs
Is it possible to route audio through separate out using vst?
How many audio tracks can vst record simultaneously? Is Vst STABLE? Cheers for any replies |
Re: cubase vst and 001- separate outs
I tested the separate in/outs on the 001 with Cubase 4.1r2. The analog i/o all seeemed to work fine. I wasn't able to get the digital i/o working (S/PDIF and ADAT).
In my experience, Cubase still crashes occasionally (which is way too much), so I generally don't use it with paying clients. It does have "autosave" which will keep you from losing much data if it crashes, however - a REALLY nice feature that should be in PTLE, but isn't. I haven't tried maxing out the # of tracks, but I've heard of people getting at least 32 and as many as 40 tracks out of Cubase on a G4 and an ATA/66 drive - more on a good SCSI drive. I've started several projects in Cubase (using midi mostly) and then transferred both midi and audio to PTLE without any real problems. The SMF file doesn't remember OMS output settings, so you have to write down the output assignment and re-assign when you import it. Audio translates just fine because with 4.1r2, you can export the audio files as sdii and directly import to PTLE. Earlier versions of Cubase would not export to sdii (even though the menu option was there). If you have the older version of Cubase (4.1r1 or earlier) You could try to import aiff, but I haven't tried that myself. ------------------ LW
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Boom - Separate outs | Tomy DeClerque | Virtual Instruments | 12 | 02-26-2021 09:06 AM |
MBox 2 can't have 4 separate outs? | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2008 09:24 AM |
STRIKE SEPARATE OUTS | eddie lamb | Virtual Instruments | 6 | 05-31-2008 06:35 PM |
how do I export separate LE tracks to Cubase SX? | lonestarparis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-08-2006 09:44 AM |
Can't separate s/pdif output from Analog outs | St Mix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2004 03:31 PM |
