Old 03-14-2000, 04:05 AM
jack2cannon jack2cannon is offline
Default stand alone CDR/W or DAT ?
Hi guys,
I need to buy a mixdown mastering deck,
and was wondering if anyone here has used the cheaper consumer type CD RECORDERS ?
Or is DAT still the way to go ?
Old 03-14-2000, 05:11 AM
Sinboy Sinboy is offline
Default Re: stand alone CDR/W or DAT ?
Of course, CDs! And you can listen to them anywhere: in your car, at a party, at your friends....[to check on the mix], on your oncle's dolby surround hi-fi, on lil' sis' radioshack discman.......
G4 PCI Graphics OS 8.6 320M RAM
Logic Audio Platinum 4.1.3
Digi001
Old 03-14-2000, 03:40 PM
Thank's Sinboy.
All those reasons you mentioned are exactly why i'd prefer to get a CD recorder.
But i wasn't sure if the actual audio quality was as good as a DAT recorder.
Also, does anyone know if 'SCMS' woul'd be a problem if i recorded from a SCMS protected CD back into pro tools 5le DIGI001 ???
Old 03-14-2000, 04:16 PM
Digital Audio is 0 and 1s. Wether you put your 0 and 1s on a CD, a Hard Drive, a DAT Tape, an ADAT tape, a computer or anything doesn't affect the quality of the sound [except DCC or MiniDisc or other non pro formats that apply digital compression to your 0 and 1 to gain storage space!]. The converters you use to convert those 0 and 1s into an analog signal do. If I assume you mix in PT and burn digitally to CD, whatever CD Burner you choose you'll have the same quality of sound, since you'll just take whatever 0 and 1s PT give you and put them on a CD. If you mix in analog and record onto a Stand alone CD burner, then it's A/D converters quality willl affect the quality of your 0 and 1's on your CD.
In plain english: buy a SCSI Yamaha 6424 ans a SCSI card and don't worry about quality other than your music's quality!
[This message has been edited by Sinboy (edited March 14, 2000).]
Digi001
192 as stand alone JonMitchell Pro Tools TDM Systems (Win) 1 12-14-2005 10:02 PM
What does DAW stand for? mdotbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 01-15-2005 06:29 AM
Stand for C8 George Ware ProControl, Control|24, Command|8 2 05-09-2004 06:56 PM
take a stand 70bit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-23-2003 03:36 PM
192 stand alone? Scanners Pro Tools TDM Systems (Mac) 1 05-13-2003 11:00 AM
