Old 01-26-2012, 09:37 AM
Farmer Dave Farmer Dave is offline
Unhappy Clip Gain and Export Clips as files
From what I can tell, the clip gain does not translate when exporting clips as files. I just did a test exporting a mix to MP3 twice, where one of the exports had 10db more clip gain, and the output files are identical.
I guess PT is really treating the clip gain as virtual, like a volume graph. I had hoped that "what I hear is what I get" when exporting a clip but that's not the case.
Old 01-26-2012, 10:01 AM
Default Re: Clip Gain and Export Clips as files
I should add that if it's rendered of course then it would "export", but then clip gain is really zero'd out.
I was hoping it would export without rendering.
Old 03-18-2012, 10:48 AM
ulysse ulysse is offline
I am new to pt10 ...got to merge a job to a colegue pt9
is coalesce , convert the equivalent of rendering what about handles
doing it clip by clip or edit selection the whole show
uly
PT10 Clip gain - multiple clips adjust at once? willco macOS 6 12-09-2018 08:39 AM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain multiple clips workflow cjwalker Pro Tools 10 0 10-12-2012 02:53 AM
Audiosuite render causes Bus thread error on clips with 'Bypased clip gain' asparknz Pro Tools HDX & HD Native Systems (Mac) 0 08-19-2012 04:04 PM
Export Clips as Files... (to mono) Ryan Young macOS 4 06-06-2012 12:41 AM
