PT 10 and Reason 6
Reason 6 opens in PT 10 but will NOT open in slave mode. Anyone else have this issue.
Re: PT 10 and Reason 6
Are you running reason in 64-bit mode? That's the default, but PT can't run 64-bit plugins yet, so no go. the fix is to find Reason in your Applications folder, then Get Info (cmd-I). In the General panel, make sure that "Open in 32-bit mode" is checked. Reason should be available (and working) in PT again...
------------------------------------------------ Colin Mansfield Bandcamp Soundcloud |
yeh, that gets it open, but then it wont run in time....
OK, now you've lost me. By not running in time, do you mean it plays back a little late? (As in it's delayed by the buffer and overhead - which in my experience is pretty low) Or is it worse than that, like maybe the clips are a little off-grid (or on a grid that's really small, i.e. 1/64th note). (This is something that used to happen to my students all the time.)
No problems with PT10 and Reason 6 here. Reason is using more cpu in rewire than in the past. However, all of my old sessions instantly sound better running through the new mixer.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
hey guys, i don't mean to sidetrack anything, but on this thread i started i'm having a midi problem with reason 5 rewired through pt10. it's slightly not synced or something. maybe this is related?
iMac 21.5" iMac10,1 Intel Core 2 Duo 3.06 GHz In this setup: Pro Tools 10 digi 003 7200 1tb external gdrive 1tb internal 1tb external 500g external |
Thank you so much!!! I rarely post a question on this forum, but I would have NEVER figured that out.
MBOX, Reason 2.0, macbook, pro-tools 7.3 (no reason plug in) | tahiti78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-11-2008 08:11 AM |
OT: Reason Drum Refill and Reason 3.0 RAM question | Joe Evans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-01-2006 11:34 PM |
Will Reason 3.0 Read Reason Adapted Files???? | remaofaes | Pro Tools TDM Systems (Mac) | 2 | 01-08-2006 12:33 PM |
Reason 3.0 and Reason Drum Kit Refill - Opinions? | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-19-2005 08:29 AM |
Upgrade PT Reason Adapted to FULL Reason ...Price? | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2003 07:04 AM |
