Mic issues
Hello, i am new to the forum i need a little assistance.
i am currently using a MacBook laptop on 10.6.8 Lepeord version and on 9.0.5 protools. Speakers are working perfectly, but my mic isnt. Its a Shure mic and everything seems plugged in right. In My system preferences, i go to sounds, and input, i selected Avid Mbox Mini, but i get no levels. Any direction would be greatly appreciated. |
Re: Mic issues
In order to record your mic, you need to select it inside pro tools. If you make a new audio track, then you will be able to select an input for that channel. After selecting the right input, switch the track into record ready mode, now you'll see the input signal on the meters.
my blog:Tamas Dragon |
Re: Mic issues
Doing a bit more research, i have a Shure SM58 mic and it seems other are having the same issue
Re: Mic issues
Launch Pro Tools 9 and hold N, in the playback engine select the Avid Mbox Mini.
Now create a mono audio track, select the corresponding input and record arm, select again to taste. The issue your likely reading about the SM57 is the requirement to wind the gain up for vocals, acoustic guitars etc. It's a low output mic typically used for snares, guitar cabs etc. If your experiencing this, it's normal. If your this new to Pro Tools is may be worth checking out some books, tutorials and the air users blogs, this is pretty basic stuff but we all had to start somewhere.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Re: Mic issues
Sorry but the mic type is not really relevant here. First, as mentioned above, you should make some first steps in order to use your setup.
Re: Mic issues
ya i ended up needing a XLR to XLR cable instead of XLR to 1/4" because its a dynamic mic, everything else was correct but that.
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) | Lucky Bastard | Getting Started | 6 | 01-16-2014 03:29 PM |
No sound - asio driver issues - NTFS issues | mitchelljrickey | Windows | 0 | 06-21-2012 05:35 PM |
ProTools 9.0.5, iLok issues, Digi 003R+ issues | zachbot | Pro Tools 9 | 6 | 10-12-2011 08:19 PM |
8.0.4 Issues (Quick Punch & Mute/Solo issues) | pauledwards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-06-2010 09:35 AM |
Digital Noise Issues - Clock Source Issues? | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2010 01:55 PM |
