#81
Re: Free (possibly useful) App - Plug Tools v1.0
Wow, can you go work for digidesign please?
Sorry I mean avid. Here you go: Code:
20/04/2010 19:34:46 Plug Tools[2029] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.csv 20/04/2010 19:35:05 Plug Tools[2036] Unarchiving reference plugin store from /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.plist 20/04/2010 19:35:05 Plug Tools[2036] Problem unarchiving /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.plist. 0 records found. 20/04/2010 19:35:05 Plug Tools[2036] Problem unarchiving /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.plist. 0 records found. 20/04/2010 19:36:08 Plug Tools[2036] Parsing csv string... 20/04/2010 19:36:08 Plug Tools[2036] Found 0 records. 20/04/2010 19:36:08 Plug Tools[2036] Record 1 has 0 elements (should be 8). 20/04/2010 19:36:08 Plug Tools[2036] Parsed 0 records total. 20/04/2010 19:36:08 Plug Tools[2036] Updating reference plugs from web... 20/04/2010 19:36:08 Plug Tools[2036] There are currently 0 plug-ins on local system. 20/04/2010 19:36:08 Plug Tools[2036] We have downloaded 0 new plug-ins from web. 20/04/2010 19:36:08 Plug Tools[2036] We have downloaded 0 new plug-ins from web. 20/04/2010 19:36:18 Plug Tools[2036] Unable to find any new reference plug-ins. Aborting. 20/04/2010 19:36:18 Plug Tools[2036] Unable to find any new reference plug-ins. Aborting. 20/04/2010 19:37:05 Plug Tools[2036] App is terminating. Archiving reference plug-ins... 20/04/2010 19:37:05 Plug Tools[2036] /Library/Application Support/Empty Music/Plug Tools exists and is a directory. continuing... 20/04/2010 19:37:05 Plug Tools[2036] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.plist 20/04/2010 19:37:05 Plug Tools[2036] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.mysql 20/04/2010 19:37:05 Plug Tools[2036] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.csv |
#82
Great thanks... I'm closer... can you download and run it one more time? New file here
Also could you type "defaults read com.emptymusic.Plug-Tools" in a terminal window and post the output? I have a good idea where it's failing, just trying to figure out why...
Mark |
#83
Great idea and great app! Definitely has a future. You should post it in the LE section for those who are too intimidated to enter the HD/TDM forums.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
#84
OK, here's the console output from the new version:
Code:
21/04/2010 09:58:47 Plug Tools[227] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.csv 21/04/2010 09:59:29 Plug Tools[237] Updating reference plugs from web... 21/04/2010 09:59:29 Plug Tools[237] Updating reference plugs from web... 21/04/2010 09:59:29 Plug Tools[237] We have a valid URL: 'http://emptymusic.com/software/plugtools/pluginlist.php'. Continuing... 21/04/2010 09:59:30 Plug Tools[237] Unable to convert http://emptymusic.com/software/plugtools/pluginlist.php. Aborting. 21/04/2010 09:59:30 Plug Tools[237] There are currently 0 plug-ins on local system. 21/04/2010 09:59:30 Plug Tools[237] We have downloaded 0 new plug-ins from web. 21/04/2010 09:59:30 Plug Tools[237] We have downloaded 0 new plug-ins from web. 21/04/2010 09:59:44 Plug Tools[237] Unable to find any new reference plug-ins. Aborting. 21/04/2010 09:59:44 Plug Tools[237] Unable to find any new reference plug-ins. Aborting. 21/04/2010 10:00:03 Plug Tools[237] App is terminating. Archiving reference plug-ins... 21/04/2010 10:00:03 Plug Tools[237] /Library/Application Support/Empty Music/Plug Tools exists and is a directory. continuing... 21/04/2010 10:00:03 Plug Tools[237] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.plist 21/04/2010 10:00:03 Plug Tools[237] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.mysql 21/04/2010 10:00:03 Plug Tools[237] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.csv 21/04/2010 10:00:03 Plug Tools[237] Successfully archived plugins to /Library/Application Support/Empty Music/Plug Tools/Reference Plugins.csv And the terminal output: Code:
{ "NSSplitView Subview Frames PlugToolsSplitView" = ( "0.000000, 0.000000, 743.000000, 667.000000, NO", "744.000000, 0.000000, 845.000000, 667.000000, NO" ); "NSTableView Columns PlugToolsReferenceTable" = ( <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 08706c75 67696e49 4486>, 28, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 0656656e 646f7286>, 99, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 044e616d 6586>, 164, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 0846696c 654e616d 6586>, 147, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 0d4c6174 65737456 65727369 6f6e86>, 77, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 024f5386>, 50, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 04496e66 6f86>, 190, <040b7374 7265616d 74797065 6481e803 84014084 8484084e 53537472 696e6701 8484084e 534f626a 65637400 8584012b 0b446f77 6e6c6f61 6455524c 86>, 1000 ); "NSTableView Hidden Columns PlugToolsReferenceTable" = ( ); "NSTableView Sort Ordering PlugToolsReferenceTable" = ( ); "NSWindow Frame plugToolsMainWindow" = "-6 324 1610 704 0 0 1680 1028 "; ptSyncLabelsKeys = 1; ptUpdateReferencePlugsOnStart = 0; } |
#85
I think I found the bug, but I can't tell if I fixed it since I am unable to reproduce it on my system. So... if you wouldn't mind... I have yet another version up on my site for you to check out.
If it still doesn't work, please post the console output again. I added more debugging info that might be of help. The new version is here
Mark |
#86
It works! I am mightily impressed with your customer support
Unfortunately since I'm not running SL it's auto-marking most of them out of date, but that's hardly your fault. It's still an amazingly useful app, thank you so much. A paypal donation shall be winging it's way to you... |
#87
Wait... it's not marking them correctly, really? Let me look into it. Send me any info you can that might help. :)
Mark |
#88
No I didn't mean that, it's just a number of plugins have updates which are for SL only, so mine get marked out of date even though they are the most recent for my OS. Plus since I had to go back to 8.0.1 due to problems with -9031 errors under 8.0.3 most of my digidesign plugins get flagged. The app is doing exactly what it is supposed to now, it's not your problem.
Thanks again for your help. |
#89
Thanks a ton for the app. Will come in real handy.
Find new house music and records |
#90
It looks like a wonderful app. Unfortunately the "mark" function does not work here for some reason...
FS: Brand New Pro Tools 10 (Possibly PT 11 as well) | ctyelvis | Buy & Sell | 0 | 11-09-2013 10:53 AM |
Pro Tools LE 8 on OS X Server (possibly a repost) | TruestPain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-10-2013 06:39 PM |
Can you install free VST plug ins into pro tools? | PokerDude422 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-03-2007 09:11 PM |
Pro Tools for VISTA possibly won`t be here this year..... | EDurney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 08-26-2007 11:50 PM |
Plug-Ins compatible with Pro Tools free | Ruff | Digidesign Hardware & Software | 0 | 01-03-2001 09:33 AM |
