ASIO problem.. i think..
anybody have trouble getting their 002r to be recognized as a windows audio device? my problem is i cant get windows system sounds to play through it. when i assign the 002r as the default playback device (yes its listed there) nothing happens. and when i go back to the main control panel audio window it says "no audio device" listed for default. this is strange because WMP and PT talk to the 002r just fine. this normally wouldnt be an issue but there are other programs like MOTU symphonic instrument that dont recognize the 002r as an audio device. so i cant use standalone apps. i can only use them through PT. not a huge problem considering but is there something, perhaps the ASIO driver, at fault or is there something ive overlooked?
Re: ASIO problem.. i think..
Are you using XP or Vista?
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2 AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM www.wolfskinrecords.com www.voodoopilot.com |
Well NOT ASIO, Digi ASIO maybe.
I have the same problem with 003 and XP SP3 - Doesn't show up in the sound window in control panel. I don't use windows sound so that wasn't a problem but for some reason Band in a Box realdrums wants to use that driver even though I set up the Digi one. It would play one drum beat and remain silent for ever after. So I just reinstalled my Echo Audiofire to cater for those things. |
im using xp sp3.
hmmm. well.. i dont care much about using my windows system sounds. but i would like to get standalone apps to recognize the 002r as my audio device. i cant get my head around this. i have an mbox2pro that wont work *with PT at all with this machine but all my other apps recognized it fine. i switched to 002r to get PT to wrk and now i have trouble getting standalones and windows to recognize it. what a headache this nonesense is. all my hardware is more or less digi approved. |
Asio driver problem !? | minniPT | Windows | 18 | 12-10-2012 08:47 PM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
B4, midi and ASIO problem | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2007 06:02 AM |
ASIO Problem | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-10-2004 03:06 PM |
Digi 001 ASIO Problem | rockwilder | General Discussion | 1 | 09-29-2003 02:07 PM |
