Old 01-17-2005, 11:35 AM
GroovehouseRS GroovehouseRS is offline
Default MBox, Wavelab 4.01 and ASIO Driver Problem
I just bought a new computer and installed PT LE 6.7. Worked great right out of the box. I have used Wavelab for years and installed it. When I check the PREFERENCES in Wavelab it shows that the Digidesign ASIO driver is selected by Wavelab.
Then I load a wav file into Wavelab, hit play and get a big error message. It seems that either proTools is utilizing the driver (although the the computer has been restarted) or that the MBox (or driver ) is not supporting the sample rate or bit depth. (24 bit, 44.1khz). Also, the ASIO Control Panel is grey-ed out and NOT available in Wavelab.
The MBox is working great with both the PT software and with Windows Media Player.
Any ideas on how to correct this problem. I am posting this over on the Steinberg site as well, but I was hoping that somebody with PT and an MBox had found a fix.
Thanks
Old 01-17-2005, 11:56 AM
lemix's Avatar
lemix lemix is offline
Default Re: MBox, Wavelab 4.01 and ASIO Driver Problem
GroovehouseRS ,
Welcome to the forum..
24 bit, 44.1khz is of course supported. Make sure to close PT LE , before opening WL !
Only one app at the time !
You should see the Mbox in preferences>audio cards tab in WL.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
ASIO Driver for WAVELAB??? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2008 12:03 PM
An ASIO Driver that works with Wavelab PedMar Pro Tools TDM Systems (Win) 5 03-30-2004 10:17 AM
ASIO driver, 001 & WaveLab efernan1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-13-2003 04:35 PM
001 ASIO Driver and Wavelab DaveJDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2003 08:10 AM
Digi001 with ASIO driver on Wavelab 4 Nahvegador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2003 11:14 PM
