Old 12-30-2019, 02:37 AM
Artis Artis is offline
Default Dock Channel strip LED don't work
After upgrading to EuControl 19.12.1.23 my Dock channel strip LEDs doesn't show sel / rec / solo / mute states anymore. While they are visible in Control app, I can't get them working on dock. Fader itself works as it should be but LEDs are just black. Already tried uninstalling, trashing xml presets and reinstalling EuControl but without luck. Might happen that by mistake I have unchecked some box in EuControl settings, but then I cant find, which one. Is it bug or human mistake?
Old 12-30-2019, 07:10 AM
sjgam sjgam is offline
Default Re: Dock Channel strip LED don't work
I am getting same thing on my dock - I am on Logic Pro X. There does not appear to be any Eucontrol setting for this. So I suspect another bug.
Old 12-30-2019, 02:49 PM
BScout BScout is offline
All of that works fine here.
Have you tried just turning off/on your Dock? Also verify it has the latest firmware.
Old 12-30-2019, 09:01 PM
Yes I tried BScout. Doesn't make any change.
For additional info - running Pro tools Ultimate 19.10 on iMac 27 i7 retina Mojave. With Dock and iPad Pro trough separate CAT5 network switch & apple camera connection kit for iPad.
Dock is in that state after updating to 19.12.1.23
Old 12-31-2019, 11:42 AM
bewk's Avatar
bewk bewk is offline
Try reordering the iPad/Dock in the "My Surfaces" list (dragging the iPad on top of Dock in particular).
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
Old 01-03-2020, 06:04 AM
Today i had more time to fiddle around. Reordering changes nothing as bewk suggests.
I did instal older Eucontrol version - 19.9.1 and LEDs suddenly worked as they should be! But now I can't use control app because its on newer version. Is there a way how to get older Control app versions on iPad?
I tried to work like that but felt need for Control app more than channel strip LED, so I installed back version 19.12.1. And LEDs are black again! At least I have Control app.
Conclusion, thats a software issue. I don't know why, but latest Eucontrol versions renders channel strip LDS black. How should I submit this bug to Avid?
Old 01-03-2020, 06:15 AM
You might try uninstalling and reinstalling Eucontrol and app one more time - I did and now the Mute and Solo etc buttons light on the Dock. I am sure you know but the Eucontrol download site has a specific uninstall link.
Old 01-03-2020, 10:11 AM
Did complete uninstall with trashed prefs, reinstalled 19.12.1 Eucontrol and control app. Still same thing - channel strip LEDs are black.
Don't know why but on 19.9.1 they worked as should.
Old 01-03-2020, 12:37 PM
Is your dock firmware 1.1.20.0?
Old 01-06-2020, 12:08 AM
Yes BScout - Dock is on 1.1.20.0 firmware.
Right now I am out of ideas what is causing this to happen. I think its due Eucontrol update because LEDs works on 19.9.1
Missing Q Parameter on Channel Strip Through Dock? barden Avid S1, S3, Dock and Control App 3 09-26-2016 12:06 AM
Channel Strip YYR123 macOS 1 03-02-2013 08:45 PM
New URS Channel Strip Pro George Ware Pro Tools TDM Systems (Mac) 13 07-18-2007 11:33 AM
New URS Channel Strip Pro George Ware 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2007 09:40 AM
Renaissance channel vs Channel Strip frenchman Tips & Tricks 1 09-20-2003 05:18 AM
