  #21
Old 11-14-2011, 06:43 PM
DigiTechSupt's Avatar
Post Re: its official pt10..trainwreck
Originally Posted by soulsyn View Post
im not on here to waste time argueing with anyone,i just need a working system,
Fair enough. Our response stands - Pro Tools 10 supports the Digi 002/Digi 002Rack.
Avid Audio Tech Support
Support FAQ
  #22
Old 11-15-2011, 01:19 PM
cannondalered92 cannondalered92 is offline
Default Re: pt10 plays for about 2 mins then crashes
I have proof that PT10 and Mac OS 10.7.2 with latest drivers for 002R does work. I playback the Demo Session that comes with PT10 and only thing I had to do is to adjust the CPU % under the playback engine, no issues here. Cheers
  #23
Old 11-15-2011, 10:09 PM
mistalo mistalo is offline
Hey soul did you try the fix I figured out with the buffer issue? Read my earlier post above and hit the link to the thread I posted my fix. it worked for me. Let me know. my 003 showed up even before I downloaded the driver though. Pro tools just kept forcing back to aggregate at first until the settings "stuck". Everything kinda just eventually settled in. definitely check the driver install and avid coreaudio manager settings.
iMac 21.5" iMac10,1 Intel Core 2 Duo 3.06 GHz
In this setup:
Pro Tools 10 digi 003 7200 1tb external gdrive 1tb internal 1tb external 500g external
  #24
Old 11-16-2011, 12:02 PM
soulsyn soulsyn is offline
Hi mistalo thanks for your input,I tried ur idea with the core manager settings it didn't have any effect at all,I can use pro tools 10 ,I just can't use it the way I used pt9,last nite I loaded up a new session imported a 2 track instrumental mix,I decided to mess with the delay compensation at any setting other than none,no playback occurs when I hit play,I've been busy all week so I had no time to build the system from scratch but I will on Friday so ill post my findings
(Try this again)-PT10 Crashes At Startup PlasterPirate Pro Tools 10 14 10-30-2013 09:00 AM
VacuumPro crashes PT10.3.7 Hanswurstlsepp AAX Plug-ins 3 10-28-2013 12:53 PM
PT10 Freezes then Crashes Kieran-Joseph Windows 1 07-23-2013 12:12 AM
PT10 crashes alexmoi macOS 5 10-25-2012 06:58 PM
003 Disconnects and PT9 Crashes if left for alone for a couple mins ripekeai macOS 0 04-28-2011 03:30 PM
