Old 04-02-2012, 10:34 AM
vip76 vip76 is offline
Default Sample Rate problem 48khz
Hi.
I`ve owned an mbox 2 for a very long time now and have been using it with my Imac. I have never encountered this problem before and I`ve been searching my ass off to find a solution here, but it`s not here. Whenever I open a 48Khz session I get white noise and clicks and pops. If I set it to 44Khz theres no problem. What is the deal? It`s been working smoothly for as long as I can remember.
Heres what I have tried: Clean uninstall PT, repaired disk, checked firmware, checked cables. NADA. Can someone please help me, I`m going crazyyyyyyy.
Imac 2.66 duo core, PT LE 8.03.
Old 04-02-2012, 12:17 PM
Default Re: Sample Rate problem 48khz
Should mention I`m on OSX 10.58
Old 04-03-2012, 04:18 AM
In audio - midi setup everything looks fine. All internal and I have set Mbox 2 to 48.Khz. In headphones from the Mbox I hear then crackles and ticks, even though PT is not opened. Set it back to 44Khz and it`s quiet. Wheres the conflict? Can the coreaudio manager from digi give me any headache, cause when I try to connect this driver it says it`s not connected.
I`m in pain here
Old 04-11-2012, 06:56 AM
Anyone?
Old 04-11-2012, 10:02 AM
Ben Jenssen's Avatar
Is clock set to internal?
Anything digital connected to the mbox?
Old 04-12-2012, 01:45 AM
Hi.
Yes, set to internal on mbox. Line in / line out on th iMac is grey and it says standard.
Nothing connected to the mbox...
Old 04-13-2012, 12:15 PM
Elias Stiza Elias Stiza is offline
Question, does it make the pops when record arming tracks? or during playback too?
I imagine you've already tried this probably... change the clocking, optical/internal, then go to playback engine and change buffering size and back again to 1024, hit ok, and see if it works fine...
Infamous Sample Rate Problem - Can't get above 48khz babaji Pro Tools M-Powered (Win) 1 08-01-2012 08:31 PM
Sample Rate 48khz playing slow Gphyr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2012 09:02 PM
A few Issues I'm still having Static noise and 48khz sample rate Caatalyst Windows 16 01-18-2012 04:07 AM
For a PT8 recording sess what sample rate 44.1 or 48khz ? masta1 Pro Tools M-Powered (Win) 4 04-04-2009 04:32 AM
48KHz sample rate on SBLive espron Digidesign Hardware & Software 6 01-13-2001 03:04 PM
