Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 10-08-2019, 03:21 AM
burritozz burritozz is offline
Default ReWire Max Midi Channels?
I'm currently running Ableton as a ReWire slave to Pro Tools. I've got 16 instrument tracks in Pro Tools all routed to 16 corresponding midi tracks within Ableton. My only problem is that I can't route more than 16 Ableton tracks into Pro Tools. Pro Tools refuses to recognize another track past 16 within the Instrument panel.
Does anyone know about this cap for midi routing with Pro Tools/Rewire/Ableton? Is there a way to get around the cap so I can finish my track?
I know I can write the data to an audio track and then delete the corresponding midi track in Ableton to make room for new instruments. Although, this track is in it's early stages so I dont want to write any of the midi data to audio just yet. I still want to be able to tweak midi within Pro Tools further down the line of writing this track.
Any and all help would be greatly appreciated.
Old 10-08-2019, 09:59 AM
The Weed's Avatar
The Weed The Weed is online now
Default Re: ReWire Max Midi Channels?
Check the Audio Plugins Guide for information on ReWire and Pro Tools.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Group Midi Batch Setup Sounds to Midi Channels dudaman Pro Tools 11 0 10-08-2015 02:49 PM
Can't get multiple MIDI channels to work when using Reaper as a ReWire slave of PT11 chronocide Virtual Instruments 5 07-18-2015 11:46 AM
Single MIDI Track Output to Multiple MIDI Channels? jb_trm Pro Tools 9 2 07-11-2014 10:09 AM
ReWire dropping channels scottgreiner Pro Tools TDM Systems (Mac) 0 12-08-2003 02:58 PM
Rewire & 6.1 NO Reason Channels? jaksteruk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-17-2003 01:22 AM
