Well, it's all pretty much in the title... Avid says to use Ethernet instead WiFi, right?
So, to connect the iPad with ethernet I need a lightening adapter, so I won't be able to connect the iPad to power Am I right? Do you run it on battery? It seems so inconvenient to me... and also battery won't last like 8 hours or more what do you do to solve this problem? Thanks |
Nope.
To run it on ethernet you need the Apple Camera Connection kit and the Apple 100Mbit Ethernet adapter. The Camera Connection Kit allows you to power the iPad and Ethernet adapter at the same time. (and it is required to have the iPad on plugged-in power or the Ethernet adapter won't work) Can't use the 1GB ethernet adapter with iPads
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD Omni • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB |
but I don't get how it can power the iPad... I searched camera connection kit and it is a lightening to usb adapter... so if I plug the ethernet adapter to this what will I use to power the iPad?
![]() Quote:
This is the one you want: https://www.amazon.com/Apple-MK0W2AM...connection+kit And the ethernet dongle: https://www.amazon.com/Apple-USB-Eth...to+usb+adapter
Its not a requirement either...its just a more reliable performance. (I don't use or need one on my system BTW)
I also just use the wifi connection. Hasn't caused me any issues thus far.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx |
I use mine WiFi and don't have any issues.. my router is in the same room as my iPad/Dock though. If you're going across a studio or in a different room than your router, I can see how you might need to add an Access Point, or a range extender.
![]() Quote:
Thanks |
Ipad with ethernet! New solution with the new apple USB3 camera adapter | Ale | Post - Surround - Video | 8 | 05-26-2016 08:06 AM |
Ipad PTcontrol with ethernet connection | Ale | Avid S1, S3, Dock and Control | 1 | 02-16-2016 10:08 AM |
Control App drains battery on iPad mini | made | Avid S1, S3, Dock and Control | 0 | 08-20-2015 02:53 AM |
Avid releases Avid Studio for iPad | nst7 | Post - Surround - Video | 4 | 02-05-2012 08:26 PM |
Avid iPad Apps | Electrox | General Discussion | 2 | 03-25-2011 05:12 PM |
