Old 12-19-2017, 04:40 PM
noah330 noah330 is offline
Default Waves Q-Clone. Really Cool Plugin if you're using a hybrid setup
I wanted to post this more as an informational thing for folks that may be working in hybrid setups.
A while back I upgraded to Horizon for about $100 and I have been busy going through the plug--ins that I received as part of the package.
I figured Q-Clone would be something that I didn't use, but I have been using it quite a bit while tracking so I wanted to share my experience.
I have a pair of Warm Audio equalizers that I really, really like to use on my master buss. When I'm tracking I'll use them on acoustic/electric guitars, kick and snare, vocals, pretty much anything.
Before I discovered Q-Clone I would track and use them by committing to the track and then when it came time to mix I finally would place them across my buss. Even in bypass mode they really warm up a track.
With Q-Clone I was able to put them in bypass mode and 'clone' the curve that they add to a track. Now, I just have an instance of Q-Clone on a pair on faders that feed the master. I can get the sound of the WA-EQPs without having to dedicate the hardware to this task.
Since I like the pair so good I was going to buy another one just to use here and there but Q-Clone solved my problem and it was free.
If anyone has some hardware they want to free up it's a great solution. If there are any Q-Clone users that want the bypass mode EQ impulses let me know and I can probably figure out a way to send them to you.
Old 12-19-2017, 05:14 PM
Drew Mazurek's Avatar
Default Re: Waves Q-Clone. Really Cool Plugin if you're using a hybrid setup
Just keep in mind that it's not capturing the dynamic saturation of real analog gear, just a static EQ curve. So while it'll sort of sound like it, it certainly won't react like it as you push into it.
www.drewmazurek.com
Old 12-19-2017, 05:58 PM
Yeah, that's the thing. I'm using them in bypass on my master buss to get the flavor there. Then after I'm done tracking and my parts are committed I'll put the actual hardware on there.
Old 12-22-2017, 09:02 PM
audioluche audioluche is offline
Verry true.
But i use q-clone a lot in my mixing workflow and having done a lot of compare with plugins, i found q-clone sounds better than plugins even if it's just a static eq curve capture. My API 550B's sounds better when captured by q-clone than the waves plugins. My pulteq sound's better to. My vintage 1084, there is not a plugin who come close to sound like the captured q-clone.
For me it's the most used eq plugin in my mixes. It's always in my template and i just twist knobs and patch back and forth between my 1084, massive passive, pulteq, API and neumann DUO eq.
It's like eq'ing with hardware. Well, 95% like hardware. And the feeling is the same.
If i need a little more color, i use a good saturation plugin.
Disclaimer: i did not try UA eq plugins, i dont have a card.
Love q-clone.
Old 12-23-2017, 07:18 AM
amagras amagras is online now
It would be interesting to hear how this compares to Volko QB which is a clean 550b
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-10-2018, 01:39 AM
simon.a.billington simon.a.billington is offline
Yeah I have a friend who really likes this one too.
As was earlier stated it doesn't really catch any harmonics, but it will still get you the tonal curve.
He liked to use it at times to free up some CPU resources in instances where he's using more than one eq. It's not perfect, but will get you quite close. There are certainly secondary elements in the mix where it doesn't matter as much. Often its more desirable to sound less phat and saturated just so they can sit in the background more effectively, creating a kind of contrast that will allow the main instruments to come forward in the mix.
HTML code is On
Waves Q-Clone EQ Modeling David Correia macOS 5 11-01-2013 03:35 AM
Waves Q Clone - HEDD 192 Siegfried Meier Pro Tools TDM Systems (Mac) 10 09-16-2010 09:02 PM
Impulses for Waves Q-clone and IR-L? lydpik Tips & Tricks 4 01-05-2010 02:42 PM
Waves Q-Clone? uno1234 Pro Tools TDM Systems (Mac) 3 01-31-2005 08:16 PM
Waves new Q-Clone Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-25-2005 07:11 PM
