Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 07-28-2015, 02:02 AM
azaroth azaroth is offline
Default A little problem with pro tools first
Hello there everyone! Its been some time since I used pro tools (LE 8 to be exact) so when First was announced i was waiting to get my hands on it, and now that its here i have an issue.
No matter what i do i can not open the hardware playback option, it just freezes. Then no matter what setting in the playback option i use (interface buffer and all that) i can not get rid of the popping, clicking, and noise that comes with the playback. anyone have any advice?
Rig: Eleven rack current drivers, or asus xonar essence STX, win 8.1, overclocked 3770k, 16 gigs 1866 ram, WD caviar black enterprise edition 1.5 Tb, water cooled.)
Old 07-28-2015, 11:02 AM
DigiTechSupt's Avatar
Default Re: A little problem with pro tools first
Hi Azaroth,
Can you try to press and hold "N" while your Pro tools First is loading? That should allow you to select the correct Playback Engine.
Best Regards,
YD
Avid Audio Tech Support
Support FAQ
Old 07-28-2015, 12:08 PM
fantastic it worked! other question, hot the hell do i add the plugins i have that are in a pro tools format? and does pro tools use vst now?
Old 07-28-2015, 12:47 PM
Unfortunately, you will not be able to use your plugins if you didn't purchased it through Marketplace.
Best Regards,
YD
Support FAQ
Old 01-03-2017, 04:30 AM
RevDubzz RevDubzz is offline
I have the same problem, but when I hold the "N" key I get this: error r6025 pure virtual function call. What should I do?
Problem Opening Pro Tools 10 Files in Pro Tools 9 kat768 macOS 1 10-20-2012 04:57 PM
Pro Tools 10 Trial to Pro Tools 10 Full Version - Installation Problem janos macOS 2 01-09-2012 08:56 PM
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? Priz Windows 1 09-25-2011 01:51 PM
can't install--mac problem or pro tools problem? tutti_frutti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-10-2011 03:41 PM
Complex Pro Tools Problem: Windows 7 & Pro Tools 7 & 8 kremo5le 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-11-2010 10:42 PM
