Old 05-21-2014, 02:24 AM
Zee&Eli Zee&Eli is offline
Default low latency monitoring in Pro Tools 11 - IS THERE AN ANSWER ....?
I have encountered an intermittent problem using low latency monitoring in Pro Tools 11. When I go into Low Latency Monitoring mode, my main monitor output is muted so that the engineer or headphone feed can't hear anything. If I go out of low latency monitoring, audio is then audible.
Is there an answer to this ...?
When I make an audio track and wish to input monitor with record enabled, if I turn on low latency mode I cannot hear the audio. The meters are indicating that there is a signal present etc. If I turn low latency off, then I can hear the audio.....
Old 05-21-2014, 07:53 AM
clausiii's Avatar
clausiii clausiii is offline
This is normal. Take a look in the ProTools Reference Guide for mor information!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-21-2014, 09:10 AM
propower propower is offline
Default Re: low latency monitoring in Pro Tools 11 - IS THERE AN ANSWER ....?
Go to the i/o setup page and set the "Low Latency Monitor" output to the desired one.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 05-21-2014, 09:11 AM
Indeed. I never use LLM and simply set the playback buffer to 64 while tracking
Old 05-21-2014, 10:33 AM
Thanks for taking time out to advise me on this.
"Go to the i/o setup page and set the "Low Latency Monitor" output to the desired one."
How can you assign it the diresd output ? there was no menu to click inside this window ?
Old 05-21-2014, 10:34 AM
here is a screen shoot
Old 05-21-2014, 10:35 AM
could you please advise me on where i can find this infomation from ? I am new Pro Tools 11 .
Old 05-21-2014, 10:36 AM
http://www.avid.com/static/resources...renceGuide.pdf
Found it docment
Old 05-21-2014, 10:52 AM
clausiii's Avatar
It should be on your computer already! You can find it via the ProTools Help menu.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-21-2014, 11:00 AM
I just checked the manual and I think low latency monitoring is only available with HDN
Page 93
Pro Tools 11 Digi 003 Low Latency Monitoring Issue dizzydiscs Pro Tools 11 11 12-29-2013 02:16 PM
Low Latency Monitoring in Standard Pro Tools 9? Dizzi45Z Pro Tools 9 20 02-06-2012 08:55 PM
Pro Tools 9.0.5 - Low Latency Monitoring problem still persists xazqe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-02-2011 08:54 AM
Monitoring Latency issues 001 and Pro-Tools 6.4 LE eastwood1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 08-30-2006 01:04 AM
Pro Tools Free OS 9 monitoring latency - help!! sunlikeblood Digidesign Hardware & Software 2 12-29-2003 04:56 PM
