Hello all,
I'm new to this forum so I hope I'm in the right category. I am currently using Pro Tools 8.0.4 with an Mbox2 mini on a mac mini 2.53 GHz Intel Core Duo. Recently I have been having issues with pops and clicks. After reading everything posted in various threads (I tried everything, changing buffer size, processor # & %, etc…) I finally decided to try using the tech support utility to delete all prefs & databases. I was absolutely HORRIFIED to reopen protools afterwards, only to find out that ALL of my plugins that came with pro tools when I installed the program (audio suite, all the basic EQ, dynamics, etc…) were all gone!!! I checked my plug-ins folder and found it empty. In my unused plugins folder there are 4 there, BF essential tuner, dynamics II, EQ II, funk logic mastered, and that's IT. What happened to all of my plugins and more importantly, how can I reinstall them? I've looked all over the digidesign website to try to find the plug in installer and all I can find is the plug in updater…any help would be greatly appreciated!!! |
Pleas follow the "help us help you" guidelines at the top of this page.
(Help us Help You)<<<click here Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in) Pro Tools U-2019.10 macOS 10.14.6 APFS Second boot-macOS 10.13.6 (Avid HDX-1 Omni) (MP 5,1 / 64-Gb) (Sapphire RX-580 MVC-Edition) MOTU FW-CoreAudio (for poly recording) (SSL-HUI-MIDIoverIP) ---- music-design-creation Post Music-Sound mixing, Production-Enhancements. Audio Tuning and System Services new systems builds/upkeep ---- |
If these plug-ins are the stock plug-ins, you can simply re-install using the installer's utility.
Remember to always image your working system drive before making any changes to it.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2019.10 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
I don't know if what I'm experiencing is the same as the one posted by the op but it is certainly similar. There is a You tube video describing the method of trashing preferences that clearly states to delete the DAE folder. Well I have just found that the DAE folder contains a sub folder called DAE Prefs. That's the one you should delete! In my case the main DAE folder held most of my plugins! I guess the best solution to this problem would be to keep the plugins in a different drive. I hope this helps.
The best if you made a backup copy from the folders where you try to magic. I prefer the osx built in zip compression, it can made an arichive from the folder without change the content.
Tech Support Utility Fail | audiogeekzine | Pro Tools M-Powered (Win) | 2 | 08-23-2010 08:20 PM |
Tech support utility in PT8 | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-26-2008 09:42 PM |
Tech Support Utility wiping out plugins | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-13-2008 10:05 AM |
Pro Tools Tech Support Utility and SP3 | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-10-2008 12:34 PM |
Tech support utility | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-04-2007 01:00 AM |
