Best drives to use on Mix system
What is the best and fastest recording drives to use with my PT 6.4.1 Mix++ system. I have a dual 1.42 G4 running 10.3.8. I am now using two 36m 10k SCSI cheetahs. Can I use 15K 73m cheetahs or is there an even better alternative. Thanks!
Re: Best drives to use on Mix system
Ether should be fine but honestly I haven't used a SCSI drive in almost 10 years other than to copy off of.
Good Firewire drives should be fine with that machine
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks for the reply. I am only using the SCSI drives because of thier fast seek times and drive speeds. I just didn't know if I could use faster and bigger drives since PT archives documents don't address anything after the cheetah 36m 10k scsi drives. Do you know if I can record to Firewire during a session! Thanks again.
I have at 96k and that is when the cases had PATA drives, the new ones have SATA drives
The case needs an Oxford 911 or higher chip set ideally or get drives from a vender with a good reputation supporting the audio and film markets (OWC, Glyph, etc.)
Thank you very much. I am definately going to look into that!
I use a Glyph firewire 120 GB on a similar setup , works great
Using Tapatalk |
I use Samsung SSD Drive as system drive and record drive, so so fast.
Glyph all the way with Oxford chipset !!!!!!!
Glyph is great, but whatever can be rack-mounted and has internal power supply, or external power supply with locking connector is fine. You don't want to have power problems with your session drive.
I think a firewire enclosure with a modern 7200 RPM SATA drive inside, or an IDE-SATA adaptor to an internal SATA drive is all you'll ever need for a MIX system. Most modern drives are capable of around 150MB/s, which is 150% faster than FW800 or gigabit ethernet, and 300% faster than FW400. They'll be bottlenecked by the G4's architecture so there's not really any reason to go with an SSD or a loud 15000rpm SCSI drive.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
What drives are safe to defrag (system, project, sample drives) | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-08-2010 08:09 AM |
PT system on Firewire drives only | david_aka_mike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-09-2006 08:45 PM |
Two system drives - how do you do it ? | mersis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-24-2005 01:50 AM |
Fat 32 IDE rmoveable drives (from WIN98SE system) not accessable from XP system | steve at Your Heaven | Pro Tools TDM Systems (Win) | 7 | 06-12-2003 12:17 AM |
Speeds for System Drives and Audio Drives | Shorty B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-31-2002 08:03 PM |
