Old 12-31-2012, 02:35 PM
Friday0089 Friday0089 is offline
Default SONiVOX Wobble help!?
So I had a hankering to mess around with some Dubstep. So I bought SONiVOX's Wobble package. It was really cool... then it stopped working. It will work for a few minutes when I first open it in Pro Tools. Then suddenly it will not play any sound when I use my M-Audio KeyRig49.
When I try to record with it, it will show midi samples recorded but when I press play there is no sound. Also whenever I play a song - say a drum track - and try to use the Wobble to find a beat I may like and NO sound!! All of my other instruments work perfect. I have e-mailed SONiVOX but have had no luck with a response. Any hints would be greatly appreciated. Thanks!
Old 02-28-2013, 06:09 AM
steins steins is offline
Default Re: SONiVOX Wobble help!?
Did you get this figured out? I'm having the same trouble. I've tried to contact Sonivox support, but they don't respond.
Stein Tore
Old 02-28-2013, 05:03 PM
Yes I did. It's as stupid as turning off the loop function. That's all you need to do. Let me know if that helps!
Old 03-01-2013, 07:45 AM
Helped a lot, thank you . BTW, Sonivox actually got back to me this time with a very nice email and an explanation. They said it has something to do with how Pro Tools sends clock data while looping.
Again, thanks .
Stein Tore
Old 09-23-2013, 10:28 PM
TawnTron88 TawnTron88 is offline
I have been having the same problem. I want to know how and where do you disable loop?
Old 09-24-2013, 05:02 AM
Option-click the Play button, or go to Options and disable Dynamic Transport .
Stein Tore
Old 09-24-2013, 09:11 AM
ok I will give it a try. Thanks :)
Old 01-24-2015, 08:38 AM
schumann1000 schumann1000 is offline
I'm having the same issue. Disabling he loop playback doesn't fix it. Is there something else I'm missing?
Thanks,
Bryan Schumann
Bryan Schumann Music
Old 07-21-2018, 04:55 AM
Enrico De Paoli's Avatar
Enrico De Paoli Enrico De Paoli is offline
Worked perfectly here. Thank you!
Enrico De Paoli
World Class Music Engineering
SoniVox Wobble Dubstep Grime Generator Help!!!!! TawnTron88 Pro Tools M-Powered (Win) 0 09-23-2013 11:11 PM
Sonivox Plug ins and Pro Tools MP 9 Dohara Pro Tools M-Powered (Mac) 0 05-10-2012 12:44 PM
Sync and Wobble digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2010 09:09 PM
Cassette 'wobble' effect? paranerd Post - Surround - Video 9 03-11-2009 10:22 AM
Quicktime Window Wobble in 7.4.2 musiceditorcouk Post - Surround - Video 13 08-15-2008 02:08 PM
