Old 10-16-2012, 09:45 PM
stevedresser83 stevedresser83 is offline
Default ilok working on new MBP with usb 3
my ilok is not being recognized when plugging in to the usb 3.0 port on the new MBP. Is there a new ilok that works with usb 3?
Old 10-16-2012, 11:54 PM
Default Re: ilok working on new MBP with usb 3
How about providing a little more info, start at the "Help us Help You - READ THIS Before Posting!" link at the top of this page and provide more info as hinted at there, also what of the troubleshooting steps have you done?
And you installed the latest iLok driver?
Is it an iLok or iLok 2 (both should work)? Is it lit up solid blue? Blinking blue? OS X version? What exact model MBP? What shows up in the System Report>USB page?
Is the iLok known to work on other systems?
Unplug every other USB thing you can (including any interfaces) and reboot, is the iLok recognized then? Try all the USB 3 ports.
Do you have an USB 2 powered hub? Try plugging the iLok into that and connecting the hub to the USB 3 port, sometimes a useful diagnostic to try when USB2/USB3 things don't work.
Darryl
Old 10-17-2012, 07:14 AM
KMcK KMcK is offline
My iLok works fine on my MBP with USB3 ports. Make sure you have the latest drivers installed.
Old 10-17-2012, 09:57 AM
tamasdragon tamasdragon is offline
Given that usb is downward compatible, it should work. Check if you have the latest drivers/software for it.
my blog:Tamas Dragon
Old 10-17-2012, 03:18 PM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
I can verify that 2nd gen iLok works on rMBP without any problems using the laptop's built in USB3 port.
Main DAW: MacPRO 5.1, 8-Core Xeon 2.93GHz, 24 GB RAM, OSX 10.13.6, HDX2, PT2019 Ultimate, 2x UAD-2 Quad Satellites (v9.x) 2x HD I/Os, 1x Omni HD I/O, C|24 Control Surface
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
Old 10-17-2012, 05:39 PM
serio serio is offline
iLok 2 working fine here on 2012 13" MBP 9,2 running 10.8.2 as well.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 10-18-2012, 07:26 AM
AnnexProjekt AnnexProjekt is offline
My iLok works perfect on my MBPR.
Old 11-15-2013, 02:45 AM
TheMattHadder TheMattHadder is offline
I have this problem as well, my iLok 2 works fine in any USB 2.0 hubs whether powered or unpowered with no hiccups. Any time plugging it directly into the MBP mid-2012 15" USB 3.0 ports I have to do this whole in/out song and dance to get PT 10 or 11 to recognize the iLok. Pace software can't even run repair function or transfer licenses to the iLok from those ports, even though it sometimes can recognize the iLok being present.
Literally none of my other USB peripherals have issues but the little blue glowing bastard.
PACE's solution: $30 ZDT coverage. Stupid
-Matt C
2012 15" MacBook Pro
• 2.6GHz Quad-core Intel Core i7, NVIDIA GeForce GT 650M with 1GB GDDR5
• 16GB 1600MHz DDR3 SDRAM - 2x8GB
• 500GB Samsung 840 series SSD boot drive
• 500GB Serial ATA Drive @ 5400 rpm in optical bay
• OS X 10.8 Mountain Lion
• Pro Tools 10.3.6/11.0.2 EDU w/ MBox 3
• Logic X
• Reaper
• NI Maschine MK1
Old 11-21-2013, 09:41 PM
nichol88 nichol88 is offline
Same thing here. Recognizes the iLok about 20% of the time. A SMC reset works, but only on the next time I plug it in. Can't Sync/Repair. All support told me was that mid-2012 MBP's have issues with USB 3.0 backward compatibility. I think it's BS. I can't even do remote recording right now because it's a toss-up if Pro Tools will even launch.
Mid-2012 Macbook Pro, OS 10.8.5. Pro Tools 10/11. All latest drivers are installed. There was even a time when it did successfully complete a Sync/Repair, but it didn't change anything.
Ilok Not working txrx Windows 11 05-30-2012 03:43 AM
MP3 on iLok, Not Working... Why? M2E Pro Tools TDM Systems (Mac) 2 01-07-2009 12:03 PM
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 10:23 AM
ilok working? detroitkruk Pro Tools TDM Systems (Mac) 5 08-02-2005 08:24 AM
ilok driver not working on brand new ilok, help! joybeanstudios Pro Tools TDM Systems (Win) 2 05-30-2004 10:40 AM
