Old 05-12-2011, 01:55 AM
Siddhant Bhatia Siddhant Bhatia is offline
Angry ADC and AUX TRACK - BIG PROBLEM
Things are not getting sorted here ... Now there's a new issue that I have faced. Just started mixing a project today and I need to bring in my outboard gear.
So I have one Audio Track and One Aux Track ... Audio Send to Hardware 3-4, and Input of Aux is Hardware 3-4. Both go out of Stereo Monitor. This is the most simple send-return config. in any mix session.
A Delay is being reported - 56 samples (512 samples buffer) ... But when you actually hear what's going out and coming back in ... there is a MEGA latency ... 1176 samples (when I printed the output to an audio track, I found the latency figure) ....
So ... basically we NATIVE USERS can never use outboard gear? Because the right latency is NOT being reported ... and if we try manually entering the latency ... it STILL doesnt work right ...
Any ideas on workarounds? This is a VERY SERIOUS problem .... We can never create a SAMPLE PERFECT Aux Track ...... WOW!
Pro Tools 9.0.2
HD Native, HD Omni, HD 16x16 analog
10.6.7 Mac OS X
2 x 2.4 GHz Quad Core Intel Xeon
6 GB memory
System Boots in 32-Bit
14 Cores being used, currently
Old 05-12-2011, 07:03 AM
Jack Ruston UK Jack Ruston UK is offline
Default Re: ADC and AUX TRACK - BIG PROBLEM
The problem here is that PT has no way of knowing that you're routing the same audio out of one output and into another. Try using a hardware insert instead. So route via a bus from the audio track to the aux. Stick the hardware insert on the aux. It will then be properly compensated and your total latency will go up depending on your interface, sample rate and buffer size.
Jack
Old 05-15-2011, 09:33 AM
brickroadstudio brickroadstudio is offline
This was the same with TDM.
You also need to be sure the hardware is on parallel ins and outs which it seems like it is in this case.
Problem bussing audio from one track to another audio track harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-04-2010 01:15 PM
Track 1 & 3 problem ntime 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-02-2009 05:56 AM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 10:11 PM
can't pan track problem ? jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-22-2008 10:34 PM
Problem With Last Track elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-14-2002 12:35 PM
