Old 11-24-2010, 10:28 AM
Fidelis Fidelis is offline
Default Re: PT9 Import Session Data crash
Same problem here.
About the reboot thing. If I turn off all my audio interfaces (1 Lynx Aurora 16 and 1 192) and turn them on again I can Relauch Protools! No need for reboot. And no Karnal panic.
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
Old 11-24-2010, 11:47 AM
DigiTechSupt's Avatar
The problem is with IO Setups - the previous session probably was referencing an IO Setups with a different, incompatible, set of paths/outputs.
The workaround is to disable import of any routing assignments - you'll have to go back to reassign the outputs for the imported tracks.
Avid Audio Tech Support
Support FAQ
Old 11-24-2010, 12:40 PM
poly915 poly915 is offline
So are you saying that if I disable the Main Output Assignments, Send Output Assignments & Input Assignments under the "Track Data to Import" selector in the Import Session Data window, the crash will not occur?
Old 11-24-2010, 01:04 PM
Yes, looks like the problem is on the i/o setup BUT, disabling routing assignments does NOT resolve the problem. I'm trying to import just plugins and plugins settings and PT just quits.
This is the ONLY bug I found on PT9, but it's a BIG one and it's slowing down my work a lot!
Old 11-24-2010, 01:15 PM
And I can confirm that the only workaround that really works is the onw by studiojimi (thanks!). An its a PITA...
Originally Posted by studiojimi View Post
save (and might be a good time to change the name of the session first), close your session, then open up the desired session to imported from...rename it "title_IMP" or something like that and then quickly eliminate the I/O in one fell swoop from.... say all the tracks quickly by using option click remove on any one track. Close that session and reopen your session and import away with no I/O confusion to your "early release" software. At least you'll accomplish your task until AVID figures it out on their dime.
  #16
Old 11-24-2010, 02:07 PM
Ramtitam Ramtitam is offline
Got this problem now just by importing midi playlists from one channel. Nothing else. PT still wanted to do something with the I/O setup...
Booooom PT is dead.
Tried the old StudioJimi trick and it worked.
Mac Pro 8 core Nehalem 2x2.26 GHz Quad-Core Intel Xeon, 15 GB ram, HD2 Accel, 192 I/O, PT 10, Mac OS 10.6.8. Dedicated internal drives for system and sample libraries. Recording few tracks on a network Synology NAS. More tracks on a Western Digital external FW800 drive. VI's from NI (Komplete 7), Toontrack, Spectrasonics, IK Multimedia, Vienna, MOTU (BPM), Ivory and a bunch of other plugs.
  #17
Old 11-26-2010, 03:13 AM
baka baka is offline
Originally Posted by poly915 View Post
Oh, also;
If I try to run PT9 immediately after the crash (without a reboot), I get a kernel panic on my MacPro.
yay :\
I don't know what "kernel panic" is, but if I attempt to play a song originally made in PT8, it will play for maybe a second, then freeze. After force quitting my computer will freeze if I attempt to restart. Is this related?
Its made PT9 be a huge waste of time and money for me - 3 days of work lost to trying to get it to run!
Could the problems when opening a song made in PT8 be related to the problems when importing parts of sessions? I've even removed all plug ins that aren't in PT9 and getting the i/o settings right before pressing play, but the results were the same.
iMac quad core i5 with 4Gb ram OS10.6.4
  #18
Old 11-26-2010, 09:08 AM
This isn't related to importing session data from another session. You might want to start a new topic on this problem to give tech support a chance to log it.
  #19
Old 11-29-2010, 11:33 AM
After reading posts in the "Pro Tools 9" forum relating to this issue, I'm left with a bit of confusion; does this crash only occur when ISD from a session saved with a PT version previous to 9, or does it also happen when ISD from a PT9 saved session. I would check myself, but I've been forced back to 8.0.4cs2
If the bug is not present when ISD from PT9 sessions, I could update all systems at our location to PT9 otherwise it seems to be a deal-killer for mixed version facilities.
  #20
Old 12-02-2010, 06:25 AM
marrap's Avatar
marrap marrap is offline
no problem here with ISD, I disabled input routing because when I opened a session
from other rigs, I lost my buses.
use input session data quite often, had no issues :)
wolfgang funk
marrakech prod
www.marrakechprod.com
www.linkedin.com/in/marrakechprod
https://pro-labs.imdb.com/name/nm3047395
Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX.
9.0.1 doesn't fix the Import Session Data crash poly915 macOS 4 01-07-2011 02:53 PM
Session Data import function from 8.0.4 to 9.0.0 leads to a PT crash Franco1967 Pro Tools 9 27 11-27-2010 04:31 AM
New bug? Import Session Data - Crash - Missing Video Ryan Young Pro Tools 9 0 11-15-2010 01:33 PM
Import session data causing crash in 8.1 jval Pro Tools TDM Systems (Mac) 5 08-19-2010 11:57 PM
7.4 repeatable import session data crash fman Pro Tools TDM Systems (Mac) 0 11-23-2007 12:44 AM
