Old 10-11-2009, 09:56 AM
Mekko511 Mekko511 is offline
Unhappy Please help, getting errors 9092 9093 9094 6086
errors, errors, and more errors:
9092
9093
9094
6086
I bought this Pro Tools 8 new with the Mbox2 mini and It's been 3 days of frustration. My inspiration is gone! I'm all beat up here!
I have tried everything under the sun to resolve these errors and I have not been able to record a lick!
Not even 1 track!
Help me please!
I installed PT 8.0.1 and I went through the whole page here: http://www.digidesign.com/index.cfm?...1&itemid=28469
I even created a new user account, and nothing.
I start recording, and just as I'm starting to feel happy, BAM! cuts me right off.
http://www.youtube.com/watch?v=HtR-Q4JNF5Q
Computer
Model : Dell Inspiron 1720
Windows Vista Ultimate SP1 32-bit OS
Processor Model : Intel(R) Core(TM)2 Duo CPU T9300 @ 2.50GHz
Speed : 2.7GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : Dell 0UK437
BIOS : Dell A07 02/03/2008
Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3GB DDR2 SO-DIMM
Chipset
Model : Dell Mobile PM965/GM965/GL960 Express Processor to DRAM Controller
Front Side Bus Speed : 4x 200MHz (800MHz)
Memory Bus Speed : 2x 333MHz (666MHz)
Memory Module(s)
Memory Module : Elpida EBE21UE8ACUA-6E-E 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Memory Module : Hynix (Hyundai) HYMP112S64CP6-Y5 1GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Video System
Video Adapter : NVIDIA GeForce 8400M GS (16 SM4.0 1.1GHz, 128MB DDR2 2x400MHz, PCIe 1.00 x16)
Storage Devices
WDC WD2500BEVS-75UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:)
ST31000340AS (1TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ) : 932GB (H:)
TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
RECOVERY (D:) : 10GB (NTFS) @ WDC WD2500BEVS-75UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
OS (C:) : 220GB (NTFS) @ WDC WD2500BEVS-75UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
Optical Drive (E:) : N/A @ TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache)
FreeAgent Drive (H:) : 932GB (NTFS) @ ST31000340AS (1TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ)
Peripherals
LPC Hub Controller 1 : Dell ICH8M-E (ICH8) LPC Interface Controller
LPC Legacy Controller 1 : SMSC ECE5021-NU
Audio Device : Dell 82801H (ICH8) HD Audio Controller
Audio Codec : Sigmatel 76A0h
Audio Codec : Conexant 2C06h
Serial Port(s) : 1
Disk Controller : Dell 82801H (ICH8) Ultra ATA Storage Controllers
Disk Controller : Dell Mobile SATA AHCI Controller
USB Controller 1 : Dell 82801H (ICH8) USB UHCI #4
USB Controller 2 : Dell 82801H (ICH8) USB UHCI #5
USB Controller 3 : Dell 82801H (ICH8) USB2 EHCI #2
USB Controller 4 : Dell 82801H (ICH8) USB UHCI #1
USB Controller 5 : Dell 82801H (ICH8) USB UHCI #2
USB Controller 6 : Dell 82801H (ICH8) USB UHCI #3
USB Controller 7 : Dell 82801H (ICH8) USB2 EHCI #1
FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Network Services
Wireless Adapter 1 : Dell Wireless 1395 WLAN Mini-Card (802.11g (ERP), AES-CCMP, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
please help,
-Cosme-
Last edited by Mekko511; 10-12-2009 at 12:14 PM. Reason: added video sample to this first post
Old 10-11-2009, 10:16 AM
RangerJay RangerJay is offline
Default Re: Please help, getting errors 9092 9093 9094 6086
Try this:
Go to the Device Manager, and disable the Dell Wireless 1395 WLAN Mini-Card before you launch Pro Tools.
See if this doesn't fix your interrupt problem. You can re-enable your wireless network card when you are finished using Pro Tools.
Old 10-11-2009, 10:18 AM
TCM's Avatar
TCM TCM is offline
My 2c
- disable wireless and internal audio
- I assume you record to your firewire drive!
- your Ram modules differ, I don't know if they run in Dual mode
- check your system with the DPC latency checker
- check if there is Bios update
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 12.4, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive
Old 10-11-2009, 01:40 PM
Originally Posted by RangerJay View Post
Try this:
thank you for your help,
I did that and the results are the same
Originally Posted by TCM View Post
My 2c
Yes, I am recording to my firewire drive.
I will disable the wireless and internal audio and see what happens,
-the DPC latency checker, I just found out what it is. I will run that as well and see what happens.
-I will also check for the bios update and come back here and repost.
Thank you so much for trying to help guys, I really need this to work soon for some offsite recordings.
-Cosme-
oh yeah, here's a screen recording of what is happening: http://www.youtube.com/watch?v=HtR-Q4JNF5Q
Last edited by Mekko511; 10-11-2009 at 03:24 PM. Reason: now I know what the DPC latency checker is
Old 10-11-2009, 03:30 PM
TCM's Avatar
TCM TCM is offline
DPC Latency checker
http://www.thesycon.de/eng/latency_check.shtml
Did you try a different USB socket?
Old 10-11-2009, 04:37 PM
Unfortunately I will have to continue this troubleshooting when I get home in the morning at 4am. It's time for me to go to work and I was so tempted to call out!
But, at work I might be able to do a little more research and see if I have any more options when I get home in the morning.
Because the only option I see right now is buying a new macbook pro that I cannot afford One can only dream.....
It's a shame. That I'm having this problem on a new PC.
My 6yr old mac G4 with PT 7.4 is still Rock Solid. I can record 32 tracks at 128 without a blink!
Too bad I can't drag that out to the field with the digi002 board everywhere I go!
Alright so I guess I'll be back!
Thank you,
-Cosme-
Old 10-11-2009, 05:10 PM
jazzmandan jazzmandan is offline
Cosme,
I loved your video on YouTube. I think we all have gone through the same thing. This should be required viewing for anyone considering buying PT LE. LOL.
Now, have you carefully worked thorugh,
http://duc.digidesign.com/showthread.php?t=133039?
You certainly need to disable all thats been recommended to this point. I also see your system drive is 5400 versus 7200 rpm. This may be a problem (maybe not).
The root of the problem (IMO) is communications speed with the drives during recording. The Firewire is notoriusly problematic, so read the tread specifically on this point to be sure you have a compatible FW drive and interface.
Oh and by the way, what ever software and drivers you are runing to allow you to capture the PT screen during recording, be sure to disable that also....
Good luck,
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox
09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox
10/31/2009 - Win 7 64Bit
MBox /PT not supported under Win7 - I didn't leave PT, PT left me!
11/30/2009 - MBox, REAPER
http://www.jazzmandan.com
Old 10-11-2009, 05:14 PM
TOM@METRO's Avatar
It appears that you are not running a qualified Firewire controller with a TI chipset. Dell firewire controllers are notoriously problematic with PT.
Some users have had issues with mixed RAM. Try using one brand and spread them evenly in dual channel mode.
And yes, disable the wireless. If you are running a virus program you might try disabling that too.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-11-2009, 08:52 PM
Originally Posted by jazzmandan View Post
Cosme,
LOL! Yes I agree! to kind of like get their feet wet before they jump in
Good luck,
Yes, I went through that whole entire article. I started at 9pm last night and finished at 5am this morning. When I was done I looked like this
I'm not running a qualified firewire controller?
hmm... I didn't think that was an issue since I don't have a problem editing HD Video from and to that firewire hard drive with no problem for the past 3 months or so.
I guess I can look at that after I rule out the RAM situation.
I noticed the mix RAM. I was wondering about that?
That's how Dell shipped it to me.
I did disable the wireless and McAfee and had no change.
So I guess it's operation time when I get home in the morning
So I'll try to get another Elpida 2GB DDR2 and replace the Hynix (Hyundai) HYMP112S64CP6-Y5 1GB DDR2 SO-DIMM.
in the mean time if anyone else has any other info please post.
I should be home by 4am to continue the troubleshooting.
thanks all,
-Cosme-
Old 10-11-2009, 09:52 PM
danander11 danander11 is offline
I think that more importantly than looking at the RAM, you'd better sort out: WDC WD2500BEVS-75UST0 (250GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:)
5400 rpm drives are no good for PT.. and you have ONE 5400 rpm drive for both your C&D drives.
To which is your OS installed?
To which is PT installed?
To which are you recording to?
To which is your content installed?
As Tom pointed out, your firewire is probably an issue. Wireless is an issue.
Lastly, you could be getting some issues from your video card, and from your on-board sound card.
Fixing any single one of these might make an improvement, but it's likely that you will have to fix most, if not all of them.
Peace!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Constant 9092/9093/9094 errors in PT10 nuancerec macOS 3 01-24-2012 04:54 PM
Persistent 9092, 9093, 9094 and 6086 Errors on session playback MBOX2 Micro & Vista Sound Editing MunKee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2009 05:13 PM
overcome pro-tools errors 9092, 9093, 9094 Deni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2008 12:59 PM
errors 9092 9093 9094 gibboau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-20-2008 09:49 AM
-9092 -9093 -9094 errors on PT LE 5.2.1 Chuck P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-13-2004 09:24 AM
