Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 03-01-2008, 11:15 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.4cs3 Updates for all 7.4 Systems
Pro Tools 7.4cs3 updates for all Pro Tools 7.4 systems are vailable for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates
And related support sections for Pro Tools 7.4 software and hardware.
Previous installation of Pro Tools 7.4 required to use these updates:In addition to previous items from Pro Tools 7.4cs1 and 7.4cs2, the following fixes are included in Pro Tools 7.4cs3:
Pro Tools HD 7.4cs3 for Mac & Windows
Fixed: Surround Pan Automation is not Updating Properly in Loop Playback (Item # 85802)
The pan positions are correct on the first play of the selection, but can be incorrect on subsequent plays
Fixed: Playback of Surround Panning automation gets "stuck" (Item #100847)
This would only occur when writing automation with a selection highlighted while in Loop Playback mode
Fixed: Trim Values Could Be Accidentally Written To The Entire Session (Item #100795)
Steps to reproduce:
- A fader position in Latch/Trim or Touch Trim could be accidentally bumped while the transport was stopped.
- Subsequently leaving Trim mode, or manually coalescing trims would then write that bumped value to the entire track
Fixed: Pro Tools Automation Thinning Could Sometimes Remove Non-Redundant Breakpoints (Item #100794)
The thinning algorithm could mistakenly classify a breakpoint as redundant
Fixed: Certain Third Party Products Could Cause Pro Tools to crash (Item #100661)
Celemony Melodyne and AudioEase Snapper would cause a crash with tick-based regions (introduced in Pro Tools 7.4)
Fixed: Mojo - PAL QuickTime or MXF Movies Could Stutter or Display in Black and White (Item #101047)
This resulted from Mojo getting "stuck" in NTSC mode even when Pro Tools was set to PAL
Mac Only:
Fixed: Scrubbing Avid Video on the Computer Monitor Would Resize the Picture (Item #100657)
Pro Tools LE 7.4cs3 for Mac & Windows
Fixed: When Monitoring All Inputs on 003 Factory, Random Pops and Clicks Could Occur on Inputs 4-8 (Item #101084)
Although this is not likely to occur on 003 Rack, this update is recommended for both 003 Factory (console) and 003 Rack
Mac Only:
Pro Tools M-Powered 7.4cs3 for Mac & Windows
Administrator
HTML code is On
Pro Tools 7.4cs3 Updates for all 7.4 Systems Avid Post - Surround - Video 0 03-01-2008 12:02 PM
Pro Tools 7.4cs2 Updates for all 7.4 Systems Avid Post - Surround - Video 0 12-21-2007 03:59 AM
Pro Tools 7.4cs2 Updates for all 7.4 Systems Avid Technical Alerts 0 12-21-2007 02:52 AM
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems Avid Technical Alerts 0 07-26-2007 10:56 AM
Pro Tools 7.3.1cs2 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Win) 0 03-09-2007 02:40 AM
