Old 12-16-2007, 08:52 AM
rcook349 rcook349 is offline
Default Multichannel plug-in vs Multi-mono plug-in?
What's the difference between a "multichannel plug-in" and a "multi-mono plug-in"?
On my first insert at the top "D-Verb" it doesn't list either before giving me my FX choices. On the second insert, though, it lists those and then shows FX uder each.
Separately, do I want FX "D-Verb (mono)" or "D-Verb (mono/stereo)" on a vocal track? What's the difference?
Thanks!
Ron
Ronald S. Cook
Westinis, Inc.
P.O. Box 7420
Boulder, CO 80306
http://www.westinis.com
Old 12-16-2007, 10:45 AM
3JDamon 3JDamon is offline
Default Re: Multichannel plug-in vs Multi-mono plug-in?
You'll want mono/stereo for all reverbs on mono sources in order for the reverb itself to be in stereo. Multichannel plugs are used on stereo sources, and the effects processing is linked in some manner, depending on the effect. Multi-mono plugs are used on stereo sources as well, but the effect is applied to each side independently. For reverbs I would use multichannel to make sure the exact same reverbs aren't coming out both channels, which would be mono.
My most common use of multi-mono is when I need to apply different EQ to each side. Can't think of another use at the moment.
Multi Mono Plug-in repost hughwes Pro Tools TDM Systems (Win) 0 05-23-2008 12:07 PM
Phase coherency (multi-mono vs Multichannel) Ray Fabi Pro Tools TDM Systems (Mac) 0 01-21-2006 03:56 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2005 02:01 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2005 12:59 PM
Would Someone Please Explain Multi Mono Plug Ins? tomhartman Pro Tools TDM Systems (Mac) 2 07-09-2002 02:07 PM
