  #1211
Old 06-10-2008, 05:54 PM
gwattaloopy1 gwattaloopy1 is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
i was waiting for gemheny's results, but i dont know if he will
post again??????
so i went ahead and ordered. i know it is a little more expensive
but i am not recycling anything from my quadzilla.
i also went with a rack case this time.
does anybody see a problem with having 4 drives?
i wanted to do this
1. 250 system
2. 320 pro tools audio
3. 500 pro tools backups/ samples
4. 750 music library
let me know what ya'll think.
thanks ivan.
Order SummaryQty Product Description Price
1 NORCO RPC-900 Black Steel 4U Rackmount Case
1 ASUS P5K3 DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard
1 ASUS EAH3450/HTP/256M Radeon HD 3450 256MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready Video Card
1 ZALMAN ZM600-HP Continuous 600W ATX12V V2.2 / EPS12V V2.91 Modular LED Heatpipe-Cooled SLI Power Supply
1 Intel Core 2 Quad Q6700 Kentsfield 2.66GHz LGA 775 95W Quad-Core Processor Model BX80562Q6700
1 CORSAIR 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory
1 Seagate Barracuda 7200.10 ST3250310AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
1 Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
1 Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
1 Seagate Barracuda 7200.11 ST3320613AS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
1 SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B
1 Microsoft Windows XP Home With SP2B for System Builders 1 Pack
1 ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
  #1212
Old 06-12-2008, 09:40 AM
Tracy Lowery Tracy Lowery is offline
Hi Guys, Just noticed that a lot of you are using Windows XP HOME.....Any reason that you are not using XP PRO. Just Curious!!!!
Thanks, Tracy
Asus Sabertooth x79/I7-3930k/32G GSKILL
  #1213
Old 06-12-2008, 10:42 AM
sunburst79 sunburst79 is offline
Thanks, Tracy
Xp Home is just fine, recognises multicore Processers and has less processes running than Xp Pro. Its also cheaper
Theres no real benifit to running XP Pro unless you actually need one of its Pro only features.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #1214
Old 06-13-2008, 08:41 AM
Hi Sunburst, Thanks for the reply I really appreciate all your help. I am going to start building today. Can you please tell me about your opinion for Hardrives....I have one of the 1st version's of the 36gig WD Raptors w/ 8MB Cache ...I was thinking to use it for system drive. I think I will go to BB today and pick up an Audio Drive. Dont know to much about Seagate Barracuda 7200.10, but I see a lot of guys using here. I would like to know which drive is considered to be rated best for a DAW.
Thanks, Tracy
  #1215
Old 06-13-2008, 11:25 PM
mano111 mano111 is offline
The absolute fastest consumer drive is probably the new 2.5" Velociraptor, but it may be overkill as its $300 for 150 GB and 10000 rpm.
I use WD AAKS 400GB and 500GB drives that are quieter than most HDs. According to DIGI as long as its 7200rpm its good for the task.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #1216
Old 06-15-2008, 12:39 PM
Hi Guys, Well I guess I was in such a rush and really busy this week that I forgot a couple of things when purchasing....Duhh. I was planning on re-using my Power Supply but its not 24 pin so that was the 1st problem. Second problem is that the Arctic Cooling Freezer 7 Pro cpu fan I ordered will not fit on the ASUS P5K DELUXE/WIFI-AP as there is a heat sinc on the board thats in the way. Anyone else using this Power Supply ?(I thought So!!) Did you have to Mod it? Real Bummer. I was thinking of going to BB and getting another Power Supply and just using the stock CPU fan. I reallw want finish the build today if I can.
Thanks, Tracy
  #1217
Old 06-15-2008, 12:53 PM
mykhal c's Avatar
mykhal c mykhal c is offline
i'm usin' both exact components and did not have any problem installin' the AC7 pro on that mobo!!??
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1218
Old 06-15-2008, 01:09 PM
Well I thought there were other people using it, tell me please which way are you pointing the fan, I am using a server 4U case and I pointing it to the back, tried pointing to the front but still hitiing the heatsink on the board. Just to make sure we are talking about the exact fan here is the link.
CPU FAN
  #1219
Old 06-15-2008, 01:22 PM
mykhal c's Avatar
CPU FAN
yep, we're talkin' about the same one. i'm usin' a LIAN-LI case. the actual fan itself is mounted to the side of the ram slots. this allows the fan to blow across the heat sink towards the back to the 120mm exhaust fan. hope that makes sense. and again NO problem at all with the mount.
  #1220
Old 06-15-2008, 01:29 PM
CPU FAN
Here is a pic of where it is hitting....Just look for Hittting here on the photo. This is strange!!!
[image]http://i298.photobucket.com/albums/mm252/Tracymonroephoto/HittingHerePic.jpg[/image]
i7 Builds - Specs and Results mykhal c Windows 6785 11-16-2019 05:25 AM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 06:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 03:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 03:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 07:51 PM
