Old 05-09-2000, 11:12 AM
Hal Knapp Hal Knapp is offline
Default corrupt session
Went to open a session in PT 5.0.....it started loading files, fades, plugs, etc. The, just as the eidt window would usually open....the session closed.
the Protools app. continues to run, other sessions open fine. But, this one session is corrupt. Is there anyway to save it? I'm under deadline (no surprise) and will have problems redoing this 20 minute session.
I read something in the past about using res-edit.
At this point anything is worth trying.
Thanks!
Old 05-09-2000, 02:25 PM
babyseal babyseal is offline
Default Re: corrupt session
Try using the Track Transfer.
First, create an empty session file w/ matching session start time and TC format. You don't have to have any actual audio tracks in it. Save and quit.
Second, start Track Transfer app (Comes w/ PT 5.0). Open your corrupt session file in "Session #1", then open the empty session file in "Session #2". Select all the audio tracks in session #1 (the corrupt one) by clicking on one track then shift-click/dragging on the rest. Click on Transfer button. After a few seconds, you should have a cleaner version of the same session file. If the Track Transfer gives you an error message, you may need to bump up its memory allocation by like 10 Megs.
Good luck
Babyseal
Corrupt Session billybroadsword Pro Tools TDM Systems (Mac) 7 03-11-2010 12:50 PM
Corrupt Session. Please Help ! Ru_C Pro Tools TDM Systems (Mac) 7 01-07-2007 07:45 PM
HELP! session won't open due to "corrupt" session! jasonmiller808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-26-2006 02:59 PM
Corrupt Session? mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-04-2004 07:24 AM
Corrupt Session? lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-17-2001 01:35 AM
