Old 02-25-2006, 05:41 PM
johnnyv johnnyv is offline
Default What is my problem? Can\'t get midi to Kontakt
Never mind. Figured it out...
J
Old 02-25-2006, 06:07 PM
Default Re: What is my problem? Can\'t get midi to Kontakt
Have you assigned an input to the Instrument Track? - some plug-in instruments require it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-26-2006, 07:39 AM
hanz marathon hanz marathon is offline
Hi J,
you should look into the instrument options (in the edit window).
There you find the menue 'controller'.
Here you can turn the controllers on and off and do some more adjustments.
Hope that helps......
best from germany
Hanz Marathon
www.marathon-music.com
Anyone else seeing this problem with Kontakt crizdee Pro Tools TDM Systems (Mac) 3 08-31-2010 02:07 PM
Kontakt 4 Problem Becharax Virtual Instruments 8 08-12-2010 05:16 PM
problem with kontakt!!! baek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-08-2006 02:51 PM
Kontakt ( seperate midi channels in PT LE problem) Earthling 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-25-2003 12:18 AM
Kontakt Midi Problem Renie Pro Tools TDM Systems (Mac) 2 10-30-2002 11:29 PM
