Old 11-18-2019, 04:41 PM
aaquilato aaquilato is offline
Default -9129 error w/ HD Native Card and Pro Tool 2019.10
This is a new spin on an old thread.
The dreaded -9129 error message.
Here's what's happening...
Running a Mac with Mojave 10.14.6
i7-7700K CPU @ 4.2Ghz
64Gb of Ram.
Running Pro Tools Ultimate 2019.10
32Gb of Ram allocated to PT.
Buffer set to 512.
Interface is Omni HD.
Everything works perfectly.
A 96 track session @ 41K with 4 plugins on every channel
6 reverbs
6 delays
PT is purring along at less than 30% on the 8 cores. Runs for hours.
No problems at all.
As soon as I connect a Digi 192 i/o the whole things goes to ****.
I've tried connecting the Omni, 192 and the HD card differently.
Tried different clocking scenarios.
No dice.
As soon as I disconnect the 192 i/o everything works again.
Has anyone experienced this?
Or anything similar with this new version of Pro Tools.
I've read lots of posts that older 192 i/o work with Pro Tools 12, etc...
What's different?
Thoughts?
AQ.
Sorry my new Mac is not part of my Sig just yet.
AQ.
Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native)
Mac OSX ML 10.8.4 running PT11.2 Native
Mac OSX Y 10.10.5 (MBP)
Old 11-19-2019, 08:37 AM
Default Re: -9129 error w/ HD Native Card and Pro Tool 2019.10
Hmmm, the 192 is no longer supported, and while Avid said they won't do anything to "break it" on purpose, it might fall victim to an update. Testing involves 2 things:
#1-roll back to the previous release of PT(2019.6 IIRC). If it works fine on that, then maybe its time to recycle the 192 or stick with 2019.6 until funds allow replacing the 192.
#2-try to borrow/rent an HD IO box and test with that. If the errors continue, then maybe the new version of PT has a bug.
You said you tried different connections and clocking, but that's pretty vague. I see only 2 connection methods, 192 off the expansion port of OMNI, or 192 directly to the second port on the HDN card. As for clocking, LoopSync is the only method I would use with this hardware, but I would double-check that the BNC connections are correct and snug
It also would be worthwhile running a DigiTest cycle to see if the 192 reports any problems
Old 11-19-2019, 01:01 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Stock cards in the 192?
(8x8 analog 8 digital)
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.10 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds/upkeep
Old 11-19-2019, 02:02 PM
Yes.
The older Digi 192 has one analog input card, one analog output card and two digital i/o cards.
I also have an Apogee Trak 2 which has an Ambus HD card installed.
If I have everything connected, all the devices are seen in the i/o window, PT will launch but won't play. I get the -9129 error message.
If I have just the 192 connected the same scenario. PT sees both devices but will not play.
If only the Omni is connected, everything works perfectly.
Answering the question about clocking.
I have an Audio Design ProBox that is used to distribute clock to all my digital reverbs including a UA 2192.
I've tried using that as I normally would.
Omni to ProBox. ProBox distributes clock to 192, 2192, Trak 2, etc...
No go.
I've taken the PrBox out of the "proverbially loop" and connected using Loop Sync.
No go.
I've done this with both the 192 and the Trak 2 connected and with just the 192 connected.
Pro Tools will not play. As soon as I hit play I get the error message.
As soon as I disconnect everything Pro Tools plays.
AND connecting the Omni directly to the ProBox with the UA2192 connected as my D/A, Pro Tools plays.
It's only when I connect another i/o device that I get the -9129 error message.
What do you think?
AQ.
Old 11-19-2019, 04:46 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
You can definitely do what you are trying to do with the 192. I have a Lynx Aurora 16, HD I/O and a 192 all connected to my Native card and do not have any issues running all the devices together.
They are all connected using Loop Sync which with the Aurora was a pain, but once got it dialed in things have been running smooth.
So if you have just the 192 connected it works or it doesn't work?
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.6 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Pro Tools HD2 8.1.1 | 2 x PCIe Core Card | 2 x Digi 192 | 2009 Mac Pro Eight Core 2.26ghz
Old 11-19-2019, 06:49 PM
DetroitT's Avatar
try removing one of the Digital cards (keep top)
(MP 5,1 / 64-Gb)
Old 11-19-2019, 07:33 PM
Thanks for the replies guys.
I will try these options and reply back.
AQ.
AQ.
Old 11-20-2019, 08:17 PM
I haven't tried just the 192 without the Omni.
Do you think that would work?
I have had the 192 connected to the Omni.
That did not work.
Both i/o devices are seen.
Clocking with the Omni as Master fails. Immediate -9129 error.
Clocking with the 192 as Master is the same.
As soon as I hit play.... -9129 error.
AQ.
Old 11-20-2019, 08:29 PM
29CountsNY's Avatar
Well it might tell you if the 192 is broke or causing the errors.
I would try it just to make sure that the 192 by itself behaves as you would expect.
www.29counts.com
Old 11-20-2019, 08:47 PM
I haven't read anywhere that Pro Tools 2019 would run with an HD Native card without one of the newer Avid I/Os.
Has this been confirmed by anyone?
Connecting an HD Native card to an older Digi 192 with no other HD interface?
AQ.
AQ.
FS : Avid HD Native PCIE card with Pro Tools Ultimate 2019.6 Perpetual License Marc Hudson Buy & Sell 0 10-28-2019 07:33 AM
Trade hd native PCIe card for hd native thunderbolt card and cash? Brandonx1 Buy & Sell 8 03-22-2015 02:45 AM
-9129 Errors: How many of you are using UAD-2 with PT Native? tclash Pro Tools HDX & HD Native Systems (Mac) 2 12-17-2012 06:02 PM
-9129 errors on HD NATIVE MBP QUAD CORE Cryos macOS 3 04-23-2012 07:47 AM
HD Native -9129 errors KMcK Pro Tools TDM Systems (Mac) 0 03-16-2011 04:31 PM
