Old 11-17-2019, 12:20 PM
senghor senghor is offline
Default mono -> stereo. How to do it in PT?
Hi!
How to make a mono track stereo. I can of cause duplicate the track, but I want to make it stereo. It will of cause be "double mono", but this way I can process them on same track and at the same time make it wide.
Win10 Home Premium, SP1
Intel i7-4770K @3,5GHz, RAM 16GB
GA-Z87N-WIFI (rev. 1 and 2)
Scarlett 6i6 and pre-amps, Pro Tools 2019.10
Old 11-17-2019, 01:01 PM
amagras amagras is offline
Default Re: mono -> stereo. How to do it in PT?
Many times when you are about to insert a plugin on a mono track you are given two options, mono and mono-stereo, use the latest
amagrasmusic.com
Old 11-17-2019, 04:13 PM
It really depends on what the end goal is. Making a mono sound have width is tricky(at best) and some things might not translate well if the final mix gets played back on a mono system(the track might simply sound mono, or it might disappear due to phase cancellation). Duplicating by itself does nothing. If you take the duplicate and nudge it in time(600-1600 samples) will help some. Using Elastic Pitch to change the pitch slightly(6-11 cents sharp or flat) will help some. If you are the player, then double-track the part. If its a guitar track, play it again. If its an electric guitar part, change amp settings or use a different guitar or pickup setting. If its a vocal part, double-tracking is the ideal way. There are some plugins that create a double so you might demo some of those and print the results(Izoptope Vocal Doubler, ReVoice Pro and Sonnox Voxdoubler are 3 options).
Mono Electric guitar tracks will work great without doubling if you pan to one side and send to a mono reverb on the opposite side(Dverb works nicely). remember to use a MONO AUX track for this
Old 11-17-2019, 04:37 PM
Unless you want to take advantage of a certain plugin's built in stereo features
amagrasmusic.com
Old 11-17-2019, 05:11 PM
Benoni's Avatar
Benoni Benoni is offline
Originally Posted by senghor View Post
Hi!
Plugin Alliance bx_stereomaker is my go to usually.
There's also Schoeps Mono Upmix
For something free, grab WIDER from Polyverse
Also, if you just duplicate your mono track and pan full LEFT/RIGHT, you'll still be right down the middle, just louder. Check it on a scope.
Old 11-18-2019, 05:44 AM
dougdi dougdi is offline
+1 for BX Stereomaker.
HTML code is On
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 06:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 08:33 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 10:01 AM
Mono/stereo Stereo mono..... What happen here ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2004 10:28 AM
stereo file to mono and mono too stereo ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2003 08:52 PM
