I have a session that has greyed-out faders (faded faders??).
Don't know how it got this way. Each fader has an input and output and is active so they should not look this way. I've attached a screen shot. Everything is fully functional, it just looks like they are inactive.
Eric Bolvin Add horns to your project!! http://www.bolvinmusic.com/horns-r-us.html 408.236.2009 |
Can be the tracks are disabled.
Can be the output route is not routed in the I/O menu in Busses submenu. Click default to reassign well the internal busses.
Mac Mini late 2012 i5 | Mac OS Mojave 10.14 | Motu 16A | Motu 828ES | Pro Tools 2019.10 Native |
Looks like tracks are routed to Analog 1-2 so it is likely default output and working on other tracks.
Likely tracks are disabled. Take a look at the left pane on mix window. You can re-enable the tracks from there. If if those are not needed now, you can also hide the tracks to help with the clutter.
![]() Quote:
Definitely nothing to do with inactive tracks, as the OP states they look inactive but they're very much active. |
That's right. they are active and fully functional.
I hit a key or clicked something that has sent me to eternal hell.
Guessing here because the screen capture shows SOME tracks, or is it showing ALL)? If all tracks are grey, then the output path is invalid. The first guess is that the "audio engine"(Setup>Hardware) is NOT set to your usual interface.
Gigabyte X79/intel i7 3930K, 32GB RAM, DIGI003 Rack https://www.facebook.com/search/top/...0sound%20works The better I drink...the more I mix..... ![]() BTW, my name is Dave, but most people call me.........................Dave |
Check your I/O setup. With my HD Native rig Pro Tools will suddenly deactivate aspects of a working I/O setup. Just happened yesterday. Working on session - saved and closed - opened another session to work on and then when I went back to the original 10 minutes later all the faders were grey and a bunch of paths were "n/a" in the setup. My solution is to re-import the extant setup and then uncheck the n/a paths and then check their new counterparts and then reassign all outputs in the session. Yay Pro Tools!
Pro Tools Ultimate 2019.5 Dell Precision T7400 32 gigs of RAM Windows 10 Pro HD Native PCIe Lynx Aurora with LT-HD Apogee Mytek |
![]() Quote:
![]() Quote:
FWIW, I really don't like the way the newer I/O manager defaults the outputs with the Busses. It's hard to remember now what the old one was like but I'm pretty sure it was easier to choose straightforward paths and it didn't use to randomly bork itself like it does now.
Everyone so far is pointing to I/O or inactive faders, but the OP is saying though that the faders have *active* inputs and outputs and are functional and passing audio, so it's not an I/O issue. I'm curious if the faders behave normally WRT automation? Also curious if there's a control surface involved?
I've never seen this, and can't really imagine what it could be if in fact faders are fully functional, passing audio, automating, etc.
http://www.richbreen.com ---------------------------------------- MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24. |
All faders and pan pots are greyed out | chrismeraz | Pro Tools 2018 | 2 | 04-20-2018 02:09 PM |
Faders Greyed Out In Sessions | Siegfried Meier | Pro Tools 12 | 5 | 12-12-2016 12:37 PM |
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) | Eduardo Apolonia | Buy & Sell | 3 | 11-24-2015 10:56 PM |
Midi IO not shown in AMS or is greyed out. When greyed out no MIDI options in Tools | drewsmith | Pro Tools TDM Systems (Mac) | 3 | 10-15-2011 07:21 PM |
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... | domsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2004 08:06 PM |
